what da sander, not for pro use
Old Sep 16, 2009 | 03:42 PM
91(si)hatchey's Avatar
Default what da sander, not for pro use
hey im looking into buying a da sander for my dad and i. what companies should i stay away from and which ones are good.
Old Sep 19, 2009 | 07:41 AM
Default Re: what da sander, not for pro use
come on guys, i know people use these. like are da sanders something that u cant really go wrong getting or what? should i just spend like $50 on one and call it a day
Old Sep 19, 2009 | 12:46 PM
SpoonSportsJunkie's Avatar
don't buy a "crapsman"
I would phone a few bodyshops and ask for advice on bang for buck -quality sanders.
Old Sep 20, 2009 | 12:01 AM
19civic93's Avatar
Depends on what he's using the DA for. Pro use or not I'd go with Dynabrade. You can get a Dynabrade DA in different orbits. 3/8", 3/16", and 3/32". Used for different applications. So get the right DA that fits what he will be mostly using it for.
Old Sep 20, 2009 | 12:37 PM
well itll b for my del sol for now. whats the difference in the sizes mean?
Old Sep 20, 2009 | 09:22 PM
19civic93's Avatar
Different orbit sizes. From coarse to fine. Ruffing up the surface to final finishing. For example, I use my 3/32" to cut and buff. I cut into my freshly cured clear with 1500 dry for the initial cut and up to 3000 wet and then I buff.
Old Sep 21, 2009 | 10:15 AM
mztykal's Avatar
Go for a IR one.
They make great compressors and good DA's. Way cheaper than a Dynabrade.
Old Sep 21, 2009 | 07:43 PM
19civic93's Avatar
Originally Posted by mztykal
Go for a IR one.
Which IR sander are you talking about? Their orbital sanders thats equivalent to Dynabrade is not much cheaper. Maybe like 20 bucks but that's it. I got an IR compressor and yes IR does make good compressors.
Old Sep 21, 2009 | 09:50 PM
well i want one for sanding down the primer and guide coating, then one for cut and buff.
Old Sep 22, 2009 | 06:04 PM
cfh01lude's Avatar
air or electric
air= hutchins one of the best
electric= dyanbrade
thats what i use they been good
wc4ohio
Apr 10, 2011 07:05 PM
2k.civic.si
Welding / Fabrication
15
Sep 30, 2010 11:34 AM
96supercharged
36
Jan 23, 2008 02:17 PM
94sol_vtec
Mar 21, 2005 12:41 PM
