boosting a 12:1 gsr motor
Old Sep 16, 2009 | 01:28 PM
hbyrd8701's Avatar
Default boosting a 12:1 gsr motor
my friend is putting together a turbo kit in a few months and I wondering will a thicker gasket will bring the c/r down somewere around 11:5:1. it will be running of the wastegate, i think it's a 8psi spring
Old Sep 16, 2009 | 02:40 PM
hbyrd8701's Avatar
Default Re: boosting a 12:1 gsr motor
bump...
Old Sep 16, 2009 | 02:52 PM
96 GSR-T's Avatar
obviously a thicker headgasket will lower the compression, however the difference between 12:1 and 11.5:1 with boost is pretty negligable, I would try to get it down to 10:1 max for a pump gas engine, a bad tank of gas and that engines going boom at 11.5:1
Old Sep 16, 2009 | 03:25 PM
non-VTEC's Avatar
he is better off replacing the pistons to something lower than 10:1 or it will have to be detuned to the point that it will probably not work well at all and run the risk of damaging something.
Old Sep 16, 2009 | 03:29 PM
xander1100's Avatar
x2
95teggy88
Nov 14, 2013 05:04 PM
respectblades
Apr 11, 2004 08:54 AM
C-Murdock
Nov 9, 2002 10:56 AM
B18C-RnVA
Sep 5, 2001 02:14 PM
