a/c compressor not kicking on!
Old Sep 16, 2009 | 01:23 PM
sins's Avatar
Default a/c compressor not kicking on!
Ok the a/c compressor is not kicking on but when i connect it straight to the battery it turns on...can anyone help me out on this thanks....
Old Sep 16, 2009 | 01:32 PM
Former User's Avatar
Default Re: a/c compressor not kicking on!
Does the condenser fan run?
Old Sep 16, 2009 | 01:41 PM
sins's Avatar
[QUOTE=RonJ@HT;39987065]Does the condenser fan run?
nope
Old Sep 16, 2009 | 01:45 PM
Is hood fuse 35 or dash fuse 13 blown?
If the fuses are fine, try jumping the pressure switch or the thermostat.
Old Sep 16, 2009 | 01:53 PM
sins's Avatar
wheres the pressure switch located at
Old Sep 16, 2009 | 01:54 PM
TheCivicMafia's Avatar
Relay might be stuck, i'd run a jumper to see if it turns on
Use a paper clip to jump from i belive what is Socket 38 or whichever has Power Constant, to the one diagonally from it
Old Sep 16, 2009 | 01:57 PM
Did you check the fuses?
Old Sep 16, 2009 | 02:44 PM
sins's Avatar
Not yet.I'm going to check when I get home
Old Sep 17, 2009 | 08:14 AM
sins's Avatar
all the fuses checked out okay
Old Sep 18, 2009 | 12:09 AM
Papa Joe's's Avatar
Kind of hard to diag without a manifold gauage set. too low of pressure could cause the system to not operate. does the system have R134 refridgerant?
Old Sep 18, 2009 | 02:51 AM
sins's Avatar
Already took care of the problem thanks honda tech
Old Sep 18, 2009 | 07:46 AM
datruzz's Avatar
hey i have the same problem, i actually tested it the wires theres no power goin into my compressor, connector can it be my relay? anyone please answer my question
Old Sep 18, 2009 | 08:12 AM
What was the solution?
Old Sep 18, 2009 | 08:51 AM
rudedawwg's Avatar
i had a similar issue and there was a plug that was unplugged behind my driver side headlight housing. this was on my ek
Old Oct 1, 2009 | 11:43 AM
sins's Avatar
sorry ronj@ht and honda tech turns out i didn't take care of the situation......ronj@ht how do you jump the pressure switch or thermostat
Old Oct 1, 2009 | 03:20 PM
Did you replace the fuses I mentioned with known good ones?
Unplug the 2P connectors and install a jumper wire that shorts the terminals.
Old Oct 2, 2009 | 05:05 AM
sins's Avatar
yes i replaced the fuses....and clueless about the second sentence
Old Oct 2, 2009 | 07:05 AM
The 2P connectors for the thermostat and pressure switch have 2 wire terminals. Get a piece of wire a few inches long and remove the wire insulation at each end. Then insert the ends of this "jumper wire" into each terminal of the 2P connector.
Old Oct 2, 2009 | 08:24 AM
sins's Avatar
after i insert one side of the wires to the pressure switch i connect the other to the battery and see if it turns on
Old Oct 2, 2009 | 09:30 AM
No.
Do you know how to pull CEL codes by jumping the 2P service connector? It's the same concept. Click here.
Cadco2011
Nov 16, 2018 06:34 AM
Justinmnhall
Jun 4, 2013 11:07 AM
Rdriver
Honda Civic (2001 - 2005)
Aug 8, 2011 10:21 AM
Linh.
Dec 24, 2005 07:11 AM
rudeman85
Sep 19, 2005 12:23 AM
