Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Still grinding
Old Sep 16, 2009 | 12:09 PM
ironworker's Avatar
Default Still grinding
Okay honda has replaced pretty much everything except for 1st,4th,5th,6th,and reverse.I just put my 500 mi break in period on it and i still grind in 2nd and 3rd????? Could it be my clutch? I ordered a new one but it took so long to get here they had to put the car back together before i got it...I just had all new shift forks put in it.Why am i still grinding?(BTW I can drive the car...also the clutch pedal is all the way to the floor befor i shift i made sure of that.) I have to wait like 3 or 4 sec to shift then it wont grind.... Thanks in advance for yalls help.
Old Sep 16, 2009 | 12:21 PM
Alex_G's Avatar
Occupy GDD
Default Re: Still grinding
Because Honda built a POS tranny. What fluid are you using and did you make sure it's full? Good luck btw, I'd be pissed if I had just had a rebuild and it was doing the same thing.
Old Sep 16, 2009 | 02:03 PM
FijiBlueFG2's Avatar
Road House
I find, for whatever reason, it goes through phases.
I'll go a couple weeks where the tranny will feel great, and then I'll go a couple weeks where I'll be popping 2nd and 3rd no matter how I drive.
Old Oct 22, 2009 | 12:33 PM
ladizzlee's Avatar
Lady Reject
i have 6,000 miles on my 09 si sedan and for some reason 80% of the time my 2nd & 3rd gear will grind and its so weird and i get sooooo pissed.
Old Oct 22, 2009 | 12:50 PM
Greg50Lt's Avatar
it might be your synchros. Also do as already listed above check you tranny fluid level.
Old Oct 22, 2009 | 01:05 PM
vladd's Avatar
if it was the clutch then i'd think it would grind in every gear, not just 2nd and 3rd . what exactly got replaced this last time? just the actual 2nd and 3rd gears, and that's it?
Old Oct 22, 2009 | 01:18 PM
xkrntamax's Avatar
it might be your syncro. after syncro replace, I still grind 2nd very sometime.
I replace my syncro after that, no more noise from changing my gear. But sometime grind on 2nd gear.
I think torque damper will help? maybe?
Old Oct 22, 2009 | 04:13 PM
i-VTEC_DOHC's Avatar
try adjusting your clutch pedal.
it may not be fully disengaged when the pedal is all the way down??
cuz my old em2 had this problem.
Old Oct 22, 2009 | 05:54 PM
Kidnkorner's Avatar
slave cylinder on this car blows. If only there was an adjustable slave cylinder available. And adjustable slave cylinder would clear your problem right up.
Bruce Banner
Acura TL, RL & ZDX
Oct 13, 2012 06:10 AM
nmb16a
Transmission & Drivetrain
Jan 31, 2010 07:43 PM
VtecDA9
Jul 16, 2003 05:47 AM
Mr Samson
Jul 4, 2003 01:58 PM
Dru-Si
Apr 6, 2003 12:01 AM
