tunerview 1 f/s
Upgrading to a tuner view 2 later and my car is down so this needs to go. I'm asking 100 shipped for it and I'm throwing in the vent mount and stuff to do a dash mount. Missing 2 screws ( I bought it like that). Sometimes the third page screen that I have show vacuum/boost shows weird numbers when it hit's boost (rarely) but other then that, no issues.
pics....
and here's a video of it working..
YouTube - Neptune tunerview
pics....
yes they will work.There is only 1 wire to connect. Hook the 4 pin wire from the tunerview to the 4 pin data logging header on the ecu and that's it.You need to configure the tunerview to your engine management (crome,ectune,neptune) and setup the pages how you want and your done.
You can see the map display in the video where it says map and then on the page in the large display where it says like 20.3 inhg.
instructions are at hrtuning.com
The map does read 100% right. It's reading right in the video and in the picture.
Sometimes only when you display the large map on the third page it will display the map value but also have a bunch of small numbers around it,but it still displays the value fine and only does it 10% of the time.Could need reflashed, or it's just a glitch on that page.
Its really not an issue I just wanted to be honest about what i'm selling.
1 wire install. Plug one end into the tunerview and the other end into the 4 pin data logging cable header on your chipped ecu.
new price 85 dollars shipped for the tunerview and mount
SC61HB
Mar 30, 2006 06:56 PM
