Suspension & Brakes Theory, alignment, spring rates....
blox sway bar + adjustable endlink
Old Sep 15, 2009 | 09:19 PM
kelviiv's Avatar
Default blox sway bar + adjustable endlink
so i'm about to pick up a blox sway bar 21mm + the blox adjustable endlinks
i'm wondering are there any advantages for running adjustable endlinks?
i have stock lcas and just aftermarket suspension,
thanks
Old Sep 18, 2009 | 12:20 PM
SoTexDC2's Avatar
Default Re: blox sway bar + adjustable endlink
The biggest advantage of the endlinks is to position the swaybar properly. I don't think OEM endlinks will work in any scenario involving a larger than factory swaybar.
The adjustable endlinks may be stiffer due to the use of heim joints, rather than rubber bushings, but the difference will be minimal on a street car.
If this is going on anything other than an ITR (which would be pointless, because the OEM ITR rear swaybar is 22mm), I would recommend some type of Sub-frame Reinforcement kit such as Beaks or ASR.
Old Sep 18, 2009 | 12:56 PM
TunerN00b's Avatar
The primary advantage of adjustable endlinks is to be able to install the ARB without preload.
If one side of the car sits lower than the other (as in common for our offset weight FWD cars), you make one endlink longer than the other so that at rest the ARB isn't already taking load.
Spherical bearings in place of bushings are stiffer (they remove the bushing slop), but don't last as long. After 3 years, mine have started squeaking and have a slight amount of slop in them that they did not have when new.
Old Sep 18, 2009 | 01:18 PM
Bailhatch's Avatar
exactly. even with a stock bar or a big aftermarket one.
Jimmy
Suspension & Brakes
Nov 26, 2010 03:09 AM
Got Utensils
Suspension & Brakes
Oct 8, 2007 11:06 PM
thegreat0ne
Aug 24, 2007 09:29 PM
giomfe
Suspension & Brakes
Aug 10, 2007 09:36 AM
DJ_CARY
41
Jul 13, 2004 10:04 PM
