will 2 ways work with component x over?
Old Sep 15, 2009 | 01:18 PM
JDMB20TDA's Avatar
Default will 2 ways work with component x over?
I have a set of polk momo component speakers in the civic, but they are blown.
So I was wondering if I were to just swap out the door speakers with some 2 way kenwoods would this work ok?
Wire them the same way I would the old component speakers (from amp to crossover to speaker) or should I splice them before the xover to benefit from the built in tweeters?
I just dont want to spend much being I will also be upgrading the rear channels.
thanks.
Old Sep 15, 2009 | 07:12 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: will 2 ways work with component x over?
No, you will make your speakers sound like pooooooo. Those crossovers were desinged to work with your blown speakers. Not some other brand. Just do away with the old x-overs and connect the new speakers like they show in there instructions.
Old Sep 16, 2009 | 05:53 AM
JDMB20TDA's Avatar
Im going to have it amped so whether or not splicing it effects how many ohms are going to the speaker I should be ok, or at least I thought it would work ok.
and whats the deal with crutchfield saying hardly any 6x9 will fit in the rear deck?
Old Sep 16, 2009 | 10:00 AM
Its not going to sound good. You can go ahead and try. Not all 6x9 are the same size. Some brands have bigger magnets then others. To big of a magnet and you will hit the trunk rails and the trunk will not close.
Old Sep 17, 2009 | 07:16 AM
JDMB20TDA's Avatar
ahhh thanks buddy, well I guess some of the problem is the rear deck cover height.
as for running 2 ways in place of a component speaker Im not sure what would cause it to sound bad?
Old Sep 17, 2009 | 08:30 AM
There are good sounding 2 ways speakers out there. Just dont use a x-over from a different set of speakers on them.
Old Sep 23, 2009 | 12:55 PM
JDMB20TDA's Avatar
just got one set installed and was going to tune the amp before installng the otherside to see how it sounded.
well it sounded like **** for about 15 seconds then just all together stopped.
I had talked with a few people from crutchfield about this setup and they pretty much said as long as its amped it shouldnt present a problem splicing before a crossover with a coaxial speaker.
any ideas, again thanks in advance.
Old Sep 23, 2009 | 01:14 PM
mrdeadman's Avatar
They let me pick
Take out the crossovers and the tweeters and try it again. Your amp could have gone into protect mode (and possibly blew a fuse) since you lowered the impedance of the load by running a crossover and tweeter in parallel with the 2ways.
Old Sep 23, 2009 | 01:28 PM
JDMB20TDA's Avatar
unfortunately my goal with buying these 2 ways was to keep the tweeters.
I will give it a try, is there anyway of running this setup while keeping the tweeters?
Old Sep 23, 2009 | 04:56 PM
JDMB20TDA's Avatar
ive eliminated the tweeters all together and now neither side get a good signal and the amp is just producing heat and sucking amps (as my lights and dash are dimming)
one side sounds super distorted the other doesnt even respond.
Old Sep 23, 2009 | 05:07 PM
mrdeadman's Avatar
They let me pick
Is the amp's protect light on? Did you check its fuses?
Old Sep 23, 2009 | 05:24 PM
JDMB20TDA's Avatar
its a Rockford fosgate and from what I can see it doesnt have any fuses other than the main power fuse.
I didnt see a protect light on, if it is how would I reset it?
Old Sep 23, 2009 | 05:28 PM
JDMB20TDA's Avatar
model Punch 501s, I cant find much infromation on it
Old Sep 23, 2009 | 07:05 PM
mrdeadman's Avatar
They let me pick
Your speakers are possibly blown. Smell them to see if they are burnt. Push the cone in carefully. If it is grinding it is screwed.
Distortion is caused when you overdrive an amp and put a clipped signal into your speakers, clipped signals tend to **** speakers up if driven for too long and too hard...
Old Sep 23, 2009 | 07:17 PM
JDMB20TDA's Avatar
I cant imagine they are blown, I never even used them. Bought them brand new from amazon.com, I threw them in today, tested them out for about a minute total.
Old Sep 23, 2009 | 07:23 PM
mrdeadman's Avatar
They let me pick
Well you might want to check just to be sure. Which speakers are they? Model and make please.
Old Sep 23, 2009 | 07:34 PM
JDMB20TDA's Avatar
infinity 6032si 6.5" 2 ways
pioneer deh p7500mp head unit
RF 501s amp
Old Sep 23, 2009 | 10:01 PM
mrdeadman's Avatar
They let me pick
Those speakers have an rms rating of 50watts into 2ohms. Your amp put 250watts rms into them at the minimum... The max power rating for the speaker is 150watts.
You really should have done your research before...
Old Sep 24, 2009 | 06:12 AM
JDMB20TDA's Avatar
well the "true ohm" infinitys are rated the same as a 4 ohm speaker. after the wiring size change and heat buildup they rate them at 4 (when really they are ~2.6ohm).
And Like I had said the volume was at zero and from there I slowly built it up, there was no way I just pumped all the amp had at once into the speakers.
Old Sep 24, 2009 | 11:31 AM
JDMB20TDA's Avatar
tried another amp and with this amp Kicker x260? something like that weaker 4 ch, all the infinitys do is click and pop.
but, When I hook up a different speaker directly to the amp it works fine.
Old Sep 24, 2009 | 02:06 PM
4gen5thtime's Avatar
if all they did is click and pop then they are blown sorry. maybe you got defective ones or you amp blew them right off the bat.
Old Sep 24, 2009 | 02:14 PM
JDMB20TDA's Avatar
yea hooked them up to a 4ch amp and I got a loud high pitch frequency out of them, without the volume turned up at all.
when I had one hooked up on the Left and the Right side a 4 ohm speaker both would pop and click. and that was a known good speaker.
wish I woulda purchased local, Now I gotta figure out what to do with them.
neither smell burnt or crunch as I depress the cones.
I may just try a 4 ohm speaker set for the front, although Ive always had goodluck with infinity.
aantle1
Audio / Security / Video
Sep 29, 2014 06:49 AM
dayvid05
Sep 7, 2009 11:49 AM
sjbmx
Jul 2, 2008 02:33 PM
