BRAKE LIGHTS DONT WORK HELP HELP
Old Sep 15, 2009 | 10:24 AM
JAYDmManny1331's Avatar
Default BRAKE LIGHTS DONT WORK HELP HELP
MY BRAKE LIGHTS DONT LIGHT UP BUT THE BULBS ARE GOOD CAN IT BE A FUSE DO THE DC EVEN HAVE A FUSE FOR BRAKE LIGHTS OR ANYTHING ELSE NEED HELP ASAP PLEASE
Old Sep 15, 2009 | 10:34 AM
hieuamn's Avatar
Default Re: BRAKE LIGHTS DONT WORK HELP HELP
How are you so sure the bulbs are good? Yes there are fuses for brake lights. Check the fuses and if that isn't the problem, change out both bulbs if not all (reverse, signal, brakes). But if its not turning on at all.. its def the fuse
Old Sep 15, 2009 | 12:03 PM
sirmugenpower's Avatar
check your breaklight switch
Old Sep 15, 2009 | 02:40 PM
i looked for a fuse labeld brake or and light found none and where is the brake light switch ?
thanks guys
Old Sep 15, 2009 | 02:50 PM
bigislandc2's Avatar
check you brake lamp sw. by the pedal and is you jump the sw. the lights should come on.
Old Sep 15, 2009 | 03:38 PM
il try later today thanks
Old Sep 15, 2009 | 04:46 PM
770_dc2's Avatar
i had the same problem this past weekend on my 96 teg and i checked all the fuse and bulbs and nothing was wrong or blown i even changed them out just to b sure and it still didin't work all my turn signal lights and reverse lights work but not the brake lights couldnt get it fix or check so didn bother to try and fix it also i was out of state as well just drove home and had a buddy drove behind me all the way home (was in NC) to GA and as we stop at the rest area my break lights all of sudden started to work again so could it be some wire problems?
Old Sep 16, 2009 | 09:31 PM
TegRr's Avatar
I agree with, bigislandc2.....Try the brake light switch and jump it.
Old Sep 16, 2009 | 10:43 PM
oodie's Avatar
Once again brake light switch.
sd619jef9
Apr 12, 2011 04:57 PM
MR Rodgers
Jan 5, 2009 02:32 PM
homeboy
Jun 15, 2004 09:42 AM
b16a2pwr
Feb 14, 2004 02:28 PM
Jdmglenn
Oct 14, 2003 07:03 PM
