dont wanna break my baby
Old Sep 15, 2009 | 09:48 AM
crx6662's Avatar
Default dont wanna break my baby
ok i have a 93 coupe blah blah blah. it has a B18C gsr motor and block is all stock as far as i know. i am running 7 psi with a good tune 660cc injectors the whole shebang. i ran a 14.1 with street tires but i want a better time. what is the limit i can run for boost on the stock motor but still be safe? i am hoping for like 10 or 12 psi?
thanks
Old Sep 15, 2009 | 09:49 AM
Ls_dx's Avatar
Default Re: dont wanna break my baby
What does your tuner recommend?
Old Sep 15, 2009 | 09:51 AM
GEN2 LS's Avatar
Loved
the 1st mod you need to do, is a "driver mod" that will greatly improve your times:p
Old Sep 15, 2009 | 09:56 AM
crx6662's Avatar
i took the car down the track 3 different tracks 6 runs all together. i hit a consistant 14.1 at 106 give or take a fewhundreths of a sec and mph but always 14.1
Old Sep 15, 2009 | 10:10 AM
cm8719500's Avatar
Icon3 Re: dont wanna break my baby
Well if you wanna take the boost higher you probably should have had it tuned at 10 or 12 psi...
Was the tune maxed out at 7 Psi??
i have a stock b16a that i run 12psi on and it runs fine...
Old Sep 15, 2009 | 10:23 AM
crx6662's Avatar
My spring is a 7psi spring so thats just what i got it tuned at.
Old Sep 15, 2009 | 10:25 AM
LightningTeg's Avatar
Community Builder
You need driver mod. 106 trap should be low 13s easy
Old Sep 15, 2009 | 03:04 PM
LS AzZkIkr's Avatar
x2! practice driving and play with you suspension if you have adjustability.
Old Sep 15, 2009 | 03:27 PM
civic_ferio's Avatar
deff play wit your suspension lowerr in the front so u get more traction but on a b series im positive u can run 12 psi i did it on my b16 also drove it all the way from florida to mass like that never gave me a problem.. but i babied that car alot too, go back to the dyno get your car tuned up to 12 psi and enjoy
Old Sep 15, 2009 | 04:21 PM
crx6662's Avatar
Ok thanks
Old Sep 16, 2009 | 09:13 AM
crx6662's Avatar
i think im goinh to go with 12psi and see what happens!
Old Sep 16, 2009 | 09:57 AM
dephtone's Avatar
You are running on street tires. You need to get some slicks, as you are spinning with street tires. If you want better times, get a set of lenso's and some seat time.
Learn to drive with what you have now. I can probably guarantee that you are running 2.3 -2.5 60' times.
Every .1 off your 60 foot is .2 off your 1/4 mile.
Old Sep 16, 2009 | 11:48 AM
jksmith's Avatar
sorry to say, even with street tires you should be better than that... a stock GSR in a EG should hit those times
Old Sep 16, 2009 | 04:36 PM
LS AzZkIkr's Avatar
https://honda-tech.com/forums/drag-racing-36/just-got-back-track-2645366/.
There is what I did on street tires.
b16a4
Dec 9, 2007 05:19 PM
recorod54
Sep 8, 2007 09:26 PM
Samuels
Mar 11, 2007 02:37 PM
turbob18a1
Sep 1, 2003 07:14 PM
Acura_I-RS
Aug 19, 2003 04:03 PM
