94 civic dx-poor mans type r
all pics of my build is under my pics.
the motor has been semi built for low boost aplication.all oem honda parts such as brand
new rod and main bearrings,pistons timing belt gaskets and seals.cosmetic thicker head gasket(.040) arp head studs,exedy clutch,avid mounts,rear disk swap wit proper praporsion valve,new dizzy,new axles,plugs,wires,hasport sub harness,p28 ecu with a skunk2 gsr chip,freshly deglazed cylinder walls by machine shop specified to each piston to wall clearence,2k miles on motor with 2 times already changed oil using valvoline oil with a oem honda oil filter and
hondas new manuel trans fluid. gsr tranny with new 3rd gear syncro,dual valve springs,gsr cams and 99 si cylinder head with 20k on it.whole bottem end came from a 99 gsr.motors compression is 9.5.
asking 4500 obo,cause of all the new parts.vehicle has a clean interior(black)needs one or two missing panels(inner door handle and wiper switch)could use a paint job and exhaust.
still for sale for 4200 obo. needs a battery. can jump start tho. will trade plus possibly money for a 88-91 ef hatch si (green) or a realy clean ef hatch. will consider dc integras just let me know what ya got
sdobson910
Apr 26, 2015 04:20 PM
wreckeddc4
Jul 3, 2011 06:36 AM
