HELP!!! with custom single turbo exhaust setup
Old Sep 15, 2009 | 08:30 AM
rwood's Avatar
New User
Default HELP!!! with custom single turbo exhaust setup
looking for some help on exhaust size from heads to collector and collector to turbo for custom turbo exhaust. i know theres guys on here that really know there ****, so for those who do please help.
Motor run down..
built 3.15 v6 6g72, 8.3:1 compression, fully ported and polished heads,1mm oversized exhaust (31.5mm) and intake (36.5) valves, 272 cams, kiggly springs (rpm 8000-8500), E85 Fuel + 50-75 shot nos, 1650cc bluemax inj, Turbo-PTE6765SP billet DBB T4 (35-40psi), looking for 800awhp. Car is fully gutted, should be around 3000lbs, primarily use will be on the street, but occasionally track.
i have the header flanges, they transition to 1 7/8" pipe. I want good spool, but dont want to effect to much top end just in case i want to go bigger turbo. Thanks for the help!!!
Old Sep 15, 2009 | 09:43 AM
russianvr4's Avatar
OG Fabricator
Default Re: HELP!!! with custom single turbo exhaust setup
doing something like this?
http://s611.photobucket.com/albums/t...ce/fab/single/
Old Sep 15, 2009 | 10:35 AM
rwood's Avatar
New User
Yes, that was the plan. Can u give me a run down on what size piping u used, what turbo, and are u happy with it performance wise?
Old Sep 15, 2009 | 10:58 AM
russianvr4's Avatar
OG Fabricator
1.5" sched 10 primaries into 2.5" crossover pipe and the turbo is a 6765 billet with a 3" exhaust for now, i'll go to a 4" later, its going to be a bitch to make it fit but doable.
the car isnt running yet so i cant say anything about performance.
Old Sep 15, 2009 | 02:11 PM
got wide's Avatar
if your looking for 800 to the wheels i wouldnt worry too much about having a quick spool. build it for max flow and let the nitrous take care of the spool up, other than that the russian pretty much gave you the whole recipe, now start cookin!
Old Sep 16, 2009 | 11:21 AM
m R g S r's Avatar
with a 3.15L engine it should actually spool that turbo rather quickly. it's got a decent amount of displacement to help get the turbo spinning!
Old Sep 16, 2009 | 12:17 PM
russianvr4's Avatar
OG Fabricator
wait till you see one with a 3.7L spooling a 6765 billet
ThatsTheTruth
Apr 25, 2006 09:57 AM
blackriceman
Apr 25, 2004 01:10 PM
92 GSR
Aug 26, 2003 04:04 PM
CalvitoSol
Jul 21, 2002 04:05 PM
