what size exhaust for turbo?
i've heard that 3" exhaust is the way to go but i've also been told that 2.5" is enough for a b16a. can anyone clear this up for me because i don't want to do "double work" later when i feel that i have to go w/ something bigger. also, i have a 94' sol. how should the turbo positioned? should the downpipe routed through the passenger side or to the driver side between the turbo and ac? anyone have similar setup w/ pix that can help out? thanx.
Re: what size exhaust for turbo? (theory48)
3in. for turbo the faster you get those exhaust gases out the fast youll go. if any go open downpipe its better the 3 in and sounds sweet but becareful of the pigs!
Re: what size exhaust for turbo? (W.ZeroB18C1T)
Does small exhause make your car lug with turbo, before I just had down pipe, and it picked up quick, no the stupid exhause guy hook up my down pipe to my stock system and the stock exhause piping and the muffler.with a 2.5 inch pipe, and it hella lugs now, could that be the reason???
Re: what size exhaust for turbo? (therumblingteg)
go 3inch but if u can get bigger like 3 1/2 inch go for it
the bigger the better
[Modified by DLB1994, 12:39 AM 7/22/2002]
Unceasing Measure
Re: what size exhaust for turbo? (DLB1994)
Re: what size exhaust for turbo? (Archidictus)
by better he means high end. 5 inch exhaust will get you great high end but you'll get a big fat on your torque...especially off the line where hondas suffer already. i wouldn't go any larger than 3''. even 3.5'' would be pushing it.
u just ever drove a turbo car with a open down pipe ,turbo will spool up faster so u will get power sooner
