where to buy slicks?
Old Aug 27, 2002 | 04:16 PM
DIRep972's Avatar
Smarter than you
Default where to buy slicks?
Where do u guys buy ur slicks from? i want to get a set of 22 by 8 by 15
Old Aug 27, 2002 | 07:50 PM
sparkz's Avatar
Default Re: where to buy slicks? (DIRep972)
exospeed.com
or kg precision engineering 714-841-8990
Old Aug 27, 2002 | 09:27 PM
ExospeedAMcrx's Avatar
the closest size M&H has to that are 23x7.5x15.
M/T does make the 22x8x15 but i heard doesnt hook up that great. but it might be diff in other cases.
Feel free to IM me for M&H info.
We stock the popular sizes, but special order sizes can be shipped out within 1-2 weeks.
Wil
Old Aug 28, 2002 | 11:46 AM
hybridreams's Avatar
Default Re: where to buy slicks? (exospeedAMcrx)
exospeed
slicks are great wil! thanks again!
Old Aug 28, 2002 | 03:30 PM
SiREF8's Avatar
Default Re: where to buy slicks? (hybridreams)
Hey did you try Performance Auto Supply over here in Mesquite, if not ask Iggy if he knows the #.
Old Aug 28, 2002 | 03:33 PM
DIRep972's Avatar
Smarter than you
Default Re: where to buy slicks? (SiREF8)
I wanted a set of M&H, would the 23" be good for a 300whp set up?
Old Aug 28, 2002 | 07:39 PM
based on your HP, the choices to start out with would be
22x8x13, 22x9x13, 24.5x.8.5x13
these are all good sizes that you can play with at the HP range you are at.
Wil
Old Aug 28, 2002 | 07:56 PM
DIRep972's Avatar
Smarter than you
wouldnt i have to modify the brakes to fit a 13" rim? thats the only reason i was thinking of going with a 15" rim is because i was under the impression thats all that could fit over stock integra brakes. also, im not buying the slicks for the hp im making now but slightly over 300-325 range. the 22's would still be best u think?
Old Aug 28, 2002 | 08:24 PM
well if you use Lenso rims, they will clear the integra brakes.
if on Bogarts, you would have to have the Bogarts with a built in spacer onthem
at 325 wheel HP, the 24.5x8.5x14 would be a good size.
but even the 22x9x13 will still work. ask Mike/ninseccrx they were using 22's in their race car.
Wil
Old Aug 28, 2002 | 08:40 PM
espanol's Avatar
you're going to blow up.
Old Aug 28, 2002 | 08:47 PM
DIRep972's Avatar
Smarter than you
Default Re: where to buy slicks? (espanol)
Old Aug 28, 2002 | 08:55 PM
DIRep972's Avatar
Smarter than you
I think ill end up going with 22's then, maybe ill have more traction problems then with the larger but i figure ill break less **** with the smaller. thanks exospeed for all the help ill b sure to give u a call when im ready.
Old Aug 28, 2002 | 09:03 PM
no problem,
step up to at least a 9" wide slick on the 22's so you get good contact patch even with a smaller tire.
22x9x13
Wil
Old Aug 28, 2002 | 09:16 PM
Arturbo's Avatar
Better than steak
25 Year Member
I say with the 22x9x13 will still allow you to race in the IDRC class you want to race in DIRep972. Plus, I would go smaller since the gear ratios will be shorter with the 13" diameter wheel.
I plan on getting this size for my setup but I never have any money, but I will get them from exospeed(will).
art
Old Aug 29, 2002 | 06:22 AM
AudioXtremes's Avatar
Default Re: where to buy slicks? (Arturbo)
art
wouldn't gear ratios be the same on a 22x8x13 and a 22x8x15? der.......
Old Aug 29, 2002 | 12:10 PM
pagong's Avatar
<----*wishing he could use 13" slicks, but, cant because of his Wilwood calipers "
SlowEG16
Apr 23, 2013 04:48 PM
Bangher4$
Jul 31, 2007 03:56 PM
J2turbo21
Apr 16, 2003 01:31 AM
allmotorhatch
Sep 24, 2002 02:05 AM
