Fuel pump wires getting hot!!!
Old Sep 14, 2009 | 04:12 PM
ef 991red's Avatar
Default Fuel pump wires getting hot!!!
Well i did my alarm install a while ago, and i add two relay for the clutch kill and the fuel pump kill, and overtime messed up my main relay, i looked around so much to find that failure, but i fixed it by replacing it with a new one and started right away, but then after a while again it started going off and on every once in a while and i could hear noises from where the relays were (whirring) 'till the time it didnt wanted to start again so i decided to get rid of them two kill switches and put a new main realy again but still fails, it just acts like is about to start but is not getting enough wattage trough the circuit i guess or i dont know since i check the voltage in the plug that goes to the main realy and is ok, and also the fuel pump wires gets real hot, does anybody has any idea of what could be the problem, i would really appreciate the help, i need my car running since the V8 is kiiling me on gas
Old Sep 15, 2009 | 05:39 PM
ef 991red's Avatar
Default Re: Fuel pump wires getting hot!!!
Somebody help pls!!
Old Sep 16, 2009 | 04:02 PM
zrickety's Avatar
sounds like you messed up somewhere in the alarm/relay kills. hard to help you when we don't know how it's wired up. you have bad connections or something. check the grounds?
Old Sep 16, 2009 | 05:01 PM
ef 991red's Avatar
well just like i said last time it did the same and i only had to replace the main relay and started right away but the i put them two kill relays again and worked for some time but now it did the same again and but this tiem it wont start even though i already tried three different main relays, all ground are well and i got rid of them relays that were cutting the signal betwen the fuel pump and the clutch lines, it just does like if the battery was low but thats it, is gettin gas and the clutch sensor is working too, ugh! i really need help on this one!
Old Sep 16, 2009 | 05:06 PM
schock3's Avatar
Check your grounds. and alarm connections.
Old Sep 18, 2009 | 05:20 PM
ef 991red's Avatar
ttt
Old Sep 25, 2009 | 01:04 PM
ef 991red's Avatar
i already found the problem, it was the relay under the middle console, which is the ignition relay or starter relay i think??? anyway MODS if you want you can erase this thread pls!! and thank you
GSR_hatch936
Feb 25, 2010 04:07 AM
nub_pwn
14
Jan 7, 2007 03:30 PM
markD.
10
Aug 23, 2006 06:15 PM
Quik Chris
Oct 9, 2002 06:50 PM
RenoRacing
Sep 8, 2002 09:41 PM
