Which cams SHOULD I use?
Can anyone suggest some cams for me to purchase... I was thinking that I might need some bigger cams... I am not sure about the current compression ratio but I believe its around 11:5?
Sleeved B18C 84mm
JE 11:1 Pistons
ACL Bearings
K1 Rods
LS Crank
Cometic HeadGasket
ARP Mainbolts
Blueprinted and balanced from ERL
Type R Head
Skunk2 Stage 2 Cams
Skunk2 Cam Gears
Supertech Flat Face Valves
Supertech Bronze Guides
Supertech Dual Valve Springs
Supertech Stem Seals
OEM Retainers
Hondata IMG
Precision 440cc Injectors
ARP Headstuds
Sleeved B18C 84mm
JE 11:1 Pistons
ACL Bearings
K1 Rods
LS Crank
Cometic HeadGasket
ARP Mainbolts
Type R Head
Skunk2 Stage 2 Cams
Skunk2 Cam Gears
OEM Retainers
Hondata IMG
ARP Headstuds
Well they werent degreed when I had it tuned with those cams. I made 192whp and 150wtq.
Now that I am going to have them degreed I figured that I should just get more aggressive cams.
The car is a DD and I run 93octane. I don't mind rough idle either. I am looking for 220-230whp
Sleeved B18C 84mm
JE 11:1 Pistons
ACL Bearings
K1 Rods
LS Crank
Cometic HeadGasket
ARP Mainbolts
Type R Head
Skunk2 Stage 2 Cams
Skunk2 Cam Gears
OEM Retainers
Hondata IMG
ARP Headstuds
Sleeved B18C 84mm
JE 11:1 Pistons
ACL Bearings
K1 Rods
LS Crank
Cometic HeadGasket
ARP Mainbolts
Type R Head
Skunk2 Stage 2 Cams
Skunk2 Cam Gears
OEM Retainers
Hondata IMG
ARP Headstuds
I have a hytech anti reversion header with a t1r exhaust.
if i got pro2s, would i need to switch out my current valvetrain? or would i be ok?
This time the motor will be clayed/degreed. If I went with the PRO2s, would I need to change out my Supertech Valvetrain for Skunk2 Pro Series Valvetrain?
