92-95 civic cd player install no chass harness
I wanna install my cd player but i got no chassis harness for a plug n play harness for cd player, i did this before but forgot the diagram or what I did. I just wanna connect the power and back speakers. this is just tempor. til i get to the junkyard to get me a harness. thanks
Use the search feature located in the top left corner of the website... or you could go buy yourself a haynes manual from autozone and look at the wiring diagram located in the back. The haynes manual is generally good for any heavy maintenance you need to perform... axle change, water pump/timing belt etc... so it will come in handy in the future.
I did ground, power, speakers. the key thing, idk what your talkin bout but im pretty sure it's all done, didn't work.. tried 2 cd players. fuses are good. also the outlet cigerette don't work. maybe something else..
check all fuses under driver side dash.
if that still doesn't help you, you can get 12v above the fuse box, heavy gauge white wire. Switched 12v is a heavy gauge yellow also above the fuse box. Your best bet is to use a digital multimeter to check any wiring before connections are made.
Here are the factory wiring colors for the radio harness:
Radio 12V white/blue
Radio Ground black
Radio Ignition yellow/red
Radio Illumination red/black
Factory Amp Turn-on n/a
Power Antenna n/a
Left Front Speaker (+/-) blue/gren-grey/black
Right Front Speaker (+/-) red/green-brown/black
Left Rear Speaker (+/-) blue/yellow-grey/white
Right Rear Speaker (+/-) red/yellow-brown/white
hope this helps.
Radio Ground black
Power Antenna n/a
hope this helps.
Radio to Car
yellow to white/blue
black to black
red to yellow/red
orange to red/black(or don't connect)
blue has no connection
white to blue/green
white/black to grey/black
grey to red/green
grey/black to brown/black
green to blue/yellow
green/black to grey/white
purple to red/yellow
purple/black to brown/white
black to black
red to yellow/red
white to blue/green
grey to red/green
There's little spots to connect to in the under dash fuse box and I know at least one turns on when you turn the key on. Just connect to there for your "switch" voltage. Run 12v from your battery or somewhere that can handle like 10A. I ran my amp like that for a few months with no issues. The switch power just tells the radio or amp to turn on, that's it. It doesn't supply the power needed to run the device.
Little Rage
Audio / Security / Video
May 26, 2004 04:50 PM
