question about cd player installation...
Old May 26, 2004 | 04:17 AM
Little Rage's Avatar
Default question about cd player installation...
I currently have a sony tape player installed in my car from previous driver. I am buying a new cd player today and am wondering if I would need an installation kit or wiring harness to install it? Not sure if the wiring for the tape player will match up with cd player.
Old May 26, 2004 | 05:02 AM
GAtegs's Avatar
Default Re: question about cd player installation... (Little Rage)
I doubt the harness will be the same. You can either buy the necessary harnesses to make the unit plug and play, or you can manually connect each wire. Depends on you.
Old May 26, 2004 | 08:16 AM
EFz6er's Avatar
Default Re: question about cd player installation... (a98tegLS)
The stock to aftermarket wireharness is the same I bet...you will have to cut the wires from your cassette deck to the aftermarket wire harness and connect the new deck wire harness to the aftermarket one...
You shouldnt need to buy anything other than the new deck
Old May 26, 2004 | 04:50 PM
thanks for the help. I didn't need anything else. Just had to pop out the tape player and unhook the wires and they fit perfectly into the new cd player.
si_23
Apr 10, 2011 01:56 PM
lancerkid06
Jun 15, 2007 05:45 PM
accord03coupe
Audio / Security / Video
Oct 4, 2005 04:12 AM
excoupe97
Apr 2, 2004 05:06 AM
SteveeeO
Jul 23, 2003 10:11 AM
