Just changed HEADGASKET, still smoking bad!
Old Sep 14, 2009 | 10:01 AM
honda_hackett's Avatar
Default Just changed HEADGASKET, still smoking bad!
so i have a boosted d16z6 and when i first did the swap i didnt notice it smoked really at all but now it smokes (white) alot! i just changed the headgasket and its still the same problem. im going to swap my pcv and see what happens but if that doesnt work then im guessing its the turbo or motor. its a brand new 50trim turbo though. i was just wondering what you guys might think the problem is...
Old Sep 14, 2009 | 10:02 AM
Default Re: Just changed HEADGASKET, still smoking bad!
oh and im running a 3in turboback exhaust no cat.
Old Sep 14, 2009 | 11:38 AM
jayWknight's Avatar
did you resurface the head? did you check to make sure the block deck is straight? Did you pressure test the cooling system? Always resurface the head before installing a new headgasket.
Old Sep 14, 2009 | 11:56 AM
Ruben19's Avatar
did you check for cracks
Old Sep 14, 2009 | 05:46 PM
i checked for cracks. i didnt do any resurfacing but i dont have any leaks i believe.
Old Sep 14, 2009 | 11:20 PM
:::SIRll_EJ1:::'s Avatar
If its smoking white then the problems related to low coolant, are there any leaks???
Old Sep 15, 2009 | 05:45 AM
rhdej6's Avatar
piston rings....
Old Sep 15, 2009 | 06:04 AM
Jimster480's Avatar
Originally Posted by rhdej6
piston rings....
Piston rings make you burn oil, not Coolant.
@OP it sounds like your deck or head is warped or cracked. Either that or you didnt put the headgasket on right, or didnt TQ down the head properly.
Joe Hall
Mar 21, 2013 11:50 AM
Brambo
Jul 25, 2011 07:14 AM
hassan21
14
Sep 30, 2007 10:28 PM
efking1985
13
Mar 2, 2007 09:22 AM
redzcstandardhatch
Aug 26, 2004 09:32 AM
