Wanted: OBD II Accord Engine Harness 5 speed only
Old Aug 27, 2002 | 03:14 PM
98DC2-ITR's Avatar
Default Edited: Wanted: OBD II 1997 Accord Engine Harness 5 speed only
OK guys for those of you that may have a source for one of these help me out here. I am in need of a 1996-1997 OBD II Accord Complete Engine harness. I am doing a USDM 2000 H22 into my 1997 accord and need an engine harness. I know that I can use the one on my engine I have already but to make the install as short as possible I would like to have the harness already modified and on the engine before pulling the old one out. I did this on my B16B into a '92 hatch and it worked out great. I know an automatic harness will work but I would like a 5 speed to simplify things a bit. I would like to have 5 speed only LX/DX/SE harness'. I know it is a long shot but heck it is worth a try. Any and all help you guys can give me would be appreciated....
Also for you guys who have done a swap into a 5th gen 1996 or 1997 how did you deal with the resistor box on the injectors. My engine is a 2000 H22A4 and I will be running a 1996 H22 ECU to avoid the immobilizer. It has the resistors on the injectors themselves and thereford no resistor box is needed. I will be using an Accord harness when I find one. What type of wiring is involved there? Anyhelp on that would be appreciated.
[Modified by 4thapack, 1:05 AM 8/30/2002]
Old Aug 27, 2002 | 08:59 PM
KTeller8's Avatar
Default Re: Wanted: OBD II Accord Engine Harness 5 speed only (4thapack)
hey is there a difference from auto to manual harnesses? i didnt think so. i can get you one but will run 100. thats one bill. its up to you. the guy has it but said he would take one bill for it. i cant talk him out of it. i wanted to for my swap. but ill just stop being a LAZY ***.
Old Aug 29, 2002 | 04:08 PM
98DC2-ITR's Avatar
Default Re: Wanted: OBD II Accord Engine Harness 5 speed only (KTeller8)
There are definitely differences between the auto and manual. I need a manual. Thanks anyhow. I have since revised my post to state that I need a LX/DX/SE harness. Also a wiring question has been added to the above post. HELP
Mr2kSwap
K Series
Jun 8, 2019 06:15 PM
r710
K Series
May 19, 2010 09:29 PM
AVcTcEoCrd
Sep 26, 2004 07:35 PM
Canadaccord
Apr 13, 2004 01:31 PM
