Somethings up with my Suspension. Wheel Bearing Maybe?
Old Sep 14, 2009 | 06:39 AM
imbest123's Avatar
Default Somethings up with my Suspension. Wheel Bearing Maybe?
yeah i know this video sucks but while i was doing this the wheel shook ever so slightly from left to right. anyone know what it could possibly be? im guessing more than likely a wheel bearing. its on both front wheels where this occurs:
http://www.youtube.com/watch?v=B4nvOZwckFE
Old Sep 14, 2009 | 07:14 AM
shoklid's Avatar
Default Re: Somethings up with my Suspension. Wheel Bearing Maybe?
could also b upper A arm ball joints or lowers and or t rods
Old Sep 14, 2009 | 07:16 AM
alphalanos's Avatar
Does it do it from top to bottom? They move slightly right to left because of the rack movement. Grab the tire top and bottom and see if it moves, thats most likely bearing.
Old Sep 14, 2009 | 07:45 AM
imbest123's Avatar
i was thinking this as well but im not sure.
nope not from top to bottom at all, just left to right and right to left
Old Sep 14, 2009 | 08:31 AM
alphalanos's Avatar
prob just rack movement. how old are the tie rods? if theyre old id change them just to be safe they dont cost much.
Old Sep 14, 2009 | 10:41 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Usually you can tell bad wheel bearings if the tire is able to move in any direction. Side to side by itself could be tie rods. In/out by itself could be ball joints.
See if the tire moves in all directions and also try plunging it in and out.
Then remove the wheel/tire and grab the spindle to see if it shakes. If the spindle is solid, your ball joints are fine. Then grab the tie rod end and shake it. If it doesn't move, you know it's not your tie rod.
Easy.
Old Sep 14, 2009 | 01:25 PM
imbest123's Avatar
yeah its probably a good time to get those replaced anyway. its the original 1994 suspension.
Easy.
with the wheel on all i get is the side to side play. ill try it again with the method you just told me. thanks!
MotorMouth93
Jan 22, 2018 03:54 AM
kelley_james
Jul 10, 2012 10:42 PM
boost4life1
Nov 17, 2011 02:53 PM
09egkid
Aug 6, 2010 02:54 PM
JQE80
Mar 12, 2003 01:21 PM
