turbo gsr high rpm sputter
okay so at like 6k rpm it starts to sputter and puffs of black smoke and some times a flame comes out the tail pipe. i have replaced. spark plugs, wires, roter, fuel filter, coil, map sensor. still not working right. 2 of the 5 bolts in the down pipe are being used the others are broken so i have a leak. could it be a bad fuel pump? mabey a cloged cat? what yalls opinon?
sorry i can spell well
no that sputter means your getting way rich in boost or even just driving and you will sputter and almost stall if your in boost and its alot
get a wideband and get it tuned, at least get a pretuned $30 chip from xeoncron
jdmcrx1
Aug 26, 2003 11:32 AM
