Transmission & Drivetrain Gearboxes, Differentials, Clutches
can lsd cause clunking?
Old Sep 13, 2009 | 10:35 PM
tegracer19's Avatar
Default can lsd cause clunking?
i recently bought an integra and it clunks pretty hard when turning. but it only does it for like 20 mins, after that, it goes away. the previous owner told me that the mugen lsd installed is the one causing it. is this true? if it is, can anybody tell why is it doing that? anything i can do to fix it besides buying a new tranny?
Old Sep 14, 2009 | 12:24 AM
Aquafina's Avatar
Default Re: can lsd cause clunking?
LSD's make noise. If you don't like the noise you can have the LSD replaced with a stock open diff.
Old Sep 14, 2009 | 08:54 AM
tegracer19's Avatar
Its not just a sound. It has like a hard vibration when I turn. And its not the axles either cuz it goes away after you drive it for a while
Old Sep 14, 2009 | 09:32 AM
Aquafina's Avatar
If its a Mugen LSD then it might need to be rebuilt. There shouldn't be a vibration if its working correctly.
Old Sep 14, 2009 | 09:35 PM
Mista Bone's Avatar
D Tranny Guru
Clutch style LSD without any "posi" additive will do as above, esp. a Kaaz LSD when cold.
Old Sep 14, 2009 | 09:44 PM
tegracer19's Avatar
yeah, it ony does it when its cold. why does it do that.? i would understand that it need a rebuild if it clunks all the time but it goes away after a while.
Old Sep 14, 2009 | 09:49 PM
Mista Bone's Avatar
D Tranny Guru
no oil between the clutch plates after sitting for a few hours.
I used Pennzoil Synchromesh and 1/3 tube of "positrac" additive to quiet my Kaaz down. It lasted 50K street miles which Ray @ KaazUSA was amazed at. It had more life in it but the broke the clutch nubs due to crappy track.
Old Sep 14, 2009 | 10:03 PM
tegracer19's Avatar
dude, thanks a lot for the info. i've been trying to understand this issue. haha. thanks again man
one^g
14
Nov 14, 2005 12:31 PM
turbotime
Oct 1, 2005 08:04 PM
sp0017
Aug 14, 2003 02:48 AM
calitypeR
Jul 27, 2001 06:10 PM
