b20b bearing question?
Old Sep 13, 2009 | 07:33 PM
jdmboy94's Avatar
Default b20b bearing question?
i bought a b20b for my teg after my ls threw a rod and we just got it put in and and when we fired it up it had very slight rod knock. you could barely hear it. so i cut it right off, and replaced the bearings. then fired it up again and still has knock. any suggestions?
Old Sep 13, 2009 | 07:40 PM
ls_vtec_da's Avatar
Default Re: b20b bearing question?
are the pistons aftermarket my brothers civic did the same because he has after market pistons and also barley heard it and went away.
Old Sep 13, 2009 | 07:58 PM
jdmboy94's Avatar
no its completly stock. when i pulled the pan. the crank wasnt messed up or anything. i dont think that it needs to be turned. has anyone ran oversized bearings instead of standard?
Old Sep 13, 2009 | 08:46 PM
95DC2GS-R's Avatar
In order to run oversized bearings, you're going to need to have the crank turned and resurfaced. Are you sure you used the correct bearings? (Brown, red, yellow, pink, etc)
Old Sep 14, 2009 | 07:49 AM
jdmboy94's Avatar
im pretty sure. i used standard sized bearings. im just trying to figure out why its still knocking, cause everthing else looks fine.
Old Sep 14, 2009 | 09:39 AM
ls_vtec_da's Avatar
did you check the clearances when you were rebuilding the motor you should have usually if the clearance is bad the motor knocks right when you turn it on.
Old Sep 14, 2009 | 11:04 AM
jdmboy94's Avatar
i didnt rebuild the motor, the ls threw a rod and i bought the b20 bone stock and put it in. so its all stock is a b20b
Old Sep 14, 2009 | 01:55 PM
ls_vtec_da's Avatar
sorry my bad but if there is knocking then it will probably will need a rebuild.
Old Sep 14, 2009 | 02:15 PM
8zero8's Avatar
well, you'd need to put in the right color bearings in the first place... you should check into that.
Old Sep 14, 2009 | 06:26 PM
jdmboy94's Avatar
yea i pulled the pan again tonite and when you pull on piston number 2 you can see a little movement. but its just on that one rod. the crank is not scared up or anything. and ill have to look into the color bearings. does anybody know what color is for a 97 b20b? thanks guys
Old Sep 15, 2009 | 04:23 PM
ls_vtec_da's Avatar
if that one piston moves back and forth like that then the bearings are bad and i have never heard of color bearings what do they do???
iwannarace
10
Jun 13, 2015 06:14 AM
Stonewall551
Aug 6, 2012 02:31 PM
vlc92189
21
Jan 15, 2009 09:58 AM
Infamous_Imports
May 9, 2008 08:27 PM
JScott3d
Jan 6, 2008 09:10 PM
