NEED HELP FAST OVERHEATING
Old Sep 13, 2009 | 06:30 PM
melissashelton1's Avatar
Default NEED HELP FAST OVERHEATING
let me start for the beginning i have a 98 honda civic. My car over heated due to blown raditor which in return blew my head. So I did a head swap to a z6. Once it was put all together there was a little ticking noise guy tried to adjust value but messed them all up and had me drive on it. To day I had the valves redone and there right one problem my car is now its getting way to hot hot . What could cause this. Let me add white smoke is coming out yet I replace head gasket???? Could this be due to head not being torqued right???? NOW THERE IS NO WHITE SMOKE AT ALL IT JUST BOGGING DOWN. I dont understand
Old Sep 13, 2009 | 07:04 PM
David12's Avatar
Default Re: NEED HELP FAST OVERHEATING
check your oil. if it's milky you are getting water in it.
Old Sep 13, 2009 | 08:21 PM
No oil is clean
Old Sep 13, 2009 | 08:39 PM
Former User's Avatar
This is a triple post.
Old Sep 13, 2009 | 08:43 PM
xsaxisx's Avatar
lol gtfo civics overheat?
Old Sep 13, 2009 | 10:02 PM
boxeocampeon's Avatar
hes asking for help way to be a douchebag.
check to see if theres any leaks one of your radiator or heater hoses might be leaking. is the radiator new?
Old Sep 14, 2009 | 02:30 PM
David12's Avatar
have you checked your thermostat?
Old Sep 14, 2009 | 02:32 PM
David12's Avatar
water pump? check all of the general parts of the cooling system. could be as simple as a sensor. if your radiator blew and ur rockin a stock water pump i bet it's that
Old Sep 14, 2009 | 02:39 PM
I think your right it may be the water pump. today it drove fine but i did notice a little bit of water on the drivers side so?
Old Sep 14, 2009 | 03:51 PM
tampabud's Avatar
Thermostat? Is the lower hose coming from the thermostat housing hot after driving? How fast does the engine overheat? The timing could be off causing it to overheat... does the fan kick on when it reaches operating temp?
Old Sep 14, 2009 | 04:52 PM
I took the thermo out for now replacing because it opens to slow. the lower hose not really but the upper one is. The car is not overheating today after bleeding radiator but when you get on the motor thats when it seems to over heat.. The fan was not kicking on so i bypassed it all though i replaced it. And to top it off I see wate on the ground on driver side SOO im thinking water pump. Oh and I had the timing done when I did the head swap could that be it how does the timing effect overheating???? sorry so long
Old Sep 15, 2009 | 03:38 PM
David12's Avatar
did you replace the tstat or just take it out?
the water could be coming out've your pumps wheep hole. it's very very likely that your water pump is junk, especially if you're car got so hot u blew ur head and radiator. think about it. if it was me i would replace every fragile component of the cooling system and call it a day. imagine how the plastic blades of ur pump must look if it got that hot...
Old Sep 19, 2009 | 04:04 PM
David12's Avatar
fixed the issue yet?
jeresaur
Mar 13, 2011 05:00 AM
melissashelton1
Sep 13, 2009 08:34 PM
AllMotorDB2
Nov 22, 2006 06:37 PM
GSG2
Jul 27, 2001 06:52 PM
