Hows everyone getting mass inspecions with swaps?
Old Sep 13, 2009 | 05:32 PM
95JDM's Avatar
Default Hows everyone getting mass inspecions with swaps?
Got a 97ex with a 2000 b16 swap recently used an obd2a ex ecu to get a rejection... Ive done the CKF bypass trick and still get the cel...What ecu can i use and what can i do to pass mass inspection?
Old Sep 13, 2009 | 06:32 PM
MHDesigns's Avatar
Default Re: Hows everyone getting mass inspecions with swaps?
Are you talking about passing emissions?
Old Sep 13, 2009 | 06:46 PM
98civdx's Avatar
Master Detailer
oem si ecu! your useing a sohc ecu on a dohc motor, thats not right.
i belive its p2t or you could even use a p28.
Old Sep 13, 2009 | 06:50 PM
MHDesigns's Avatar
p2t is what you should be using. You can only run a p28 if you use a conversion harness.
Old Sep 13, 2009 | 06:53 PM
98civdx's Avatar
Master Detailer
^^^ thanks! forgot to put that.
Old Sep 13, 2009 | 06:55 PM
MHDesigns's Avatar
Here's a chart of ecu's and what they came in.
http://www.hondata.com/techecuid.html
wallendiaz
Mar 14, 2013 07:27 AM
blade0314
Apr 10, 2008 01:35 PM
4thgenx42
Jan 4, 2007 05:34 AM
Bone Stock
Sep 12, 2004 08:46 PM
97 CIVIC EX
Aug 18, 2002 06:48 AM
