How to valve lash adjustment help!!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/tech-article-valve-lash-adjustment-1305086/
I could not complete it because it was confusing where it says put cil 1 or 4 in TDC, and look for sister cil. to over lap, can someone explain a little more on that? i didnt know when i was on tdc, any pics? im a noob. my rocker arms are a little loose.
lol. TDC = number 1 and 4 piston is at the top of the cylinder wall. If you didnt know what TDC is till now id say take it to a shop to get the valve lash adjusted before you damage the head/cams doing it yourself
http://www.c-speedracing.com/howto/v...alveadjust.php that might help you.
best of luck getting it figured out. TDC can be found by looking at marks on the camshaft pulley.
