valve cover information needed! parts for valve cover?Tourque?! HELP
Old Aug 27, 2002 | 01:59 PM
GroundZer0's Avatar
Default valve cover information needed! parts for valve cover?Tourque?! HELP
Ok i took my valve cover off, and one of the nut things fell in the engine, and one of the seals or whatever fell in also... where can i get there? How much do they cost?
Also about the valve cover.. it does not need to go on at a certain torque does it? Thank you. Please help me out.
Old Aug 27, 2002 | 02:07 PM
vtecrx's Avatar
Default Re: valve cover information needed! parts for valve cover?Tourque?! HELP (GroundZer0)
when you say fell into the engine are you trying to say that they fell into an oil passage? That is not good at all. You may be able to get a small magnet down the passage, if not you better hope that it fell to the bottom of the oil pan so you can pull the pan and get them out.
Andy
Old Aug 27, 2002 | 02:51 PM
GroundZer0's Avatar
actually they fell into the part with the cams and the belt? I think its the cams, if im correct they look like 2 big gears with a belt going around them, they fell into the bollow of that plastic part, and i cant get them out!
Old Aug 27, 2002 | 02:54 PM
ZCcivic91's Avatar
Um, I think you got bigger problems than getting wondering how much these cost at the local parts store. You cant let stuff fall INTO the motor and the just leave it there. It dosnt really work like that. Figure out a way to get this stuff out before you try and put the car back together.
Old Aug 27, 2002 | 02:56 PM
GroundZer0's Avatar
ROFL yes, i know this, this is why i need to get those ****** out.. come on, anyone know how to help me. Its the little plastic pice around the cams.. its a DOHC ZC engine!
P-ville
Sep 22, 2010 06:08 PM
Mr. Em1
Welding / Fabrication
10
May 2, 2009 03:38 PM
boosted91crx
Mar 31, 2009 11:19 AM
invisible
10
May 10, 2007 05:41 AM
TeamTooQuick
May 21, 2002 05:23 PM
