B20B in EG Sedan
Old Sep 12, 2009 | 09:58 PM
BassboatS13's Avatar
Default B20B in EG Sedan
okay first i have looked many places and have not found the right info i really want
I cant decide between swapping a B18B or a b20b. Problems are i want to buy from tiger or hmo because i dont trust craigslist motors etc. What is needed for the b20b from a 97-99 CRV to go into my sedan. and am i able to use my factory harness
Old Sep 12, 2009 | 10:00 PM
MHDesigns's Avatar
Default Re: B20B in EG Sedan
Please use search. it's at the top of this. There is a sticky explaining search. Good luck.
Old Sep 12, 2009 | 10:12 PM
i know how 2 use the search but im looking for defin. answers on what shift linkage and such
Old Sep 12, 2009 | 10:32 PM
MHDesigns's Avatar
You know how to search but don't know what linkage you need? Search harder(you shouldn't have time to respond to this because you will be too busy searching).
Old Sep 13, 2009 | 12:10 AM
98civdx's Avatar
Master Detailer
you searched yet you cant find out what likage to use??? you clearly dont know how to use it, there a million threads on this same thing,
any dc linkage will work,
Old Sep 13, 2009 | 01:08 PM
Civicfanatic_09's Avatar
You people should spend less time being SMART ASSES and just answer these peoples questions. Who cares if they searched for it or not, there is alot of misleading information on here, and I would want newer opinions for this stuff too. Stuff like this is what is running people off from this site. So just lay off these people. You need 94-01 integra shift linkage, axles, half shaft, transmission. You can use the stock DC mounts, or civic mounts if you wish too. You can reuse your stock engine harness, but if you use a obd2 engine, you need to switch the injectors to obd1 or find an obd2 harness and splice the obd2 injector clips on to the obd1 harness. You need a obd1 distributor and obd1 computer. You can use a p75 or pr4 computer, but you need Hondata really to make the engine run right, I am using the S100 software with a B20 basemap on it.
Old Sep 13, 2009 | 02:41 PM
how well will it run on the p75 or pr4 though because ive never heard of anyone havign to use hondata for the swap
Old Sep 13, 2009 | 02:47 PM
gutted-dx's Avatar
Hasport mounts and linkage
p75 ecu
OBD1 Distrbutor
Rest is plug in play
Old Sep 13, 2009 | 02:49 PM
gutted-dx's Avatar
O yea,
Integra axles
Think thats about it
Really try and use search to avoid everyones ****.
Old Sep 13, 2009 | 02:52 PM
p75 ecu
OBD1 Distrbutor
i was looking at getting the innovative mounts but could i get away with using a teg linkage?
Old Sep 13, 2009 | 02:58 PM
MHDesigns's Avatar
Old Sep 13, 2009 | 03:11 PM
okay.. but a member here said i could get away with using my stock civic mounts?
so far i need
p75 ecu
DC shift linkage, obd1 ecu, injectors, intake mani
mounts??
axles
half shaft?
Old Sep 13, 2009 | 03:16 PM
MHDesigns's Avatar
Get the B-series into EG mounts by hasport, or innovative. You can use any B-series axles as long at their not jap, because the jap ones are a larger hub
Old Sep 13, 2009 | 03:40 PM
gutted-dx's Avatar
****ing search this ***** been covered a thousand times.
Old Sep 13, 2009 | 03:45 PM
gutted-dx's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/engine-swap-info-faqs-how-ck-engine-lights-878010/
http://www.c-speedracing.com/howto/b18cswap/swap.php
https://honda-tech.com/forums/hybrid-engine-swaps-18/my-b20-into-ek-parts-list-504321/
Change the EK parts with EG.
Old Sep 13, 2009 | 03:51 PM
98civdx's Avatar
Master Detailer
the civic mounts can work, i know you need the dc rear mount and im not sure if you need another one or that its, but buying the hole kit would be beter, but if your on a budget.
you dont need hondata!, chip that bitch on chrome tune it and youll be fine.
p75 ecu and a obd1 integra ls dizzy.
use a dc half shaft and axles, bascily everything can come from a integra, dcs and egs have simialar parts.
Old Sep 13, 2009 | 04:47 PM
For the last time,
94-01 integra axles
94-01 integra half shaft
94-95 intake manifold
94-01 intrgra trans
94-01 integra rear bracket
Obd1 distributor
If you get a obd2 engine you need obd1 injectors, or a obd2 harness for the injector plugs. You can use your stock civic mounts if you want to. You can run a B20 off a P75, P74, or PR4, but it will run lean, trust me I just done my swap. You could buy a fuel pressure regulator and give it more fuel, but it needs more fuel. If you don't spend money on mounts, (you don't have to) you can but Hondata and run your engine right, or you can chip your ecu for chrome, uberdata, or turbo edit, but B20 needs a B20 base map to properly run. This is a super easy swap, shouldn't be this many questions on it.
Old Sep 13, 2009 | 05:42 PM
ALLxMOTOR EG's Avatar
Vietnamese!
I heard alot of horror stories purchasing at tigerjapanese.
https://honda-tech.com/forums/sales-feedback-157/attention-victims-tigerjapanese-2581123/
Hmo is a reliable company, excellent customer service.
Many people would vouch for them on HT.
Old Sep 13, 2009 | 05:52 PM
Jimster480's Avatar
Ya you have to be wary about buying motors off of Craigslist. Unless its a block, etc. But you could search on here and get a nice motor if someone has one for sale.
Dont worry about people ragging on you about search, the search doesnt always yeild the results you need.
Jimmy
Mar 16, 2015 12:16 PM
Jimmy
91
Sep 28, 2012 01:58 PM
Devo94ac
Nov 16, 2005 01:07 PM
Kato7997
Mar 3, 2003 03:23 PM
