no crank, fuel, or spark????
So i drove my car home from a friends house one night... went inside and slept... when i woke up my car wouldnt start. The radio and headlights and all work but my windows dont work. My fuel pressure guage is sitting at 0 and my fuel pump doesnt even kick on. The ignition just clicks with no crank. im out of ideas
Here is a list of things ive tried already:
ignition switch
clutch switch
battery
Throw me ideas please i need my car back bad.
***UPDATE***
the car no longer has power to the radio or to the instument cluster
ignition switch
clutch switch
battery
***UPDATE***
First problem is that it doesn't crank. You said it clicks. Is it a bunch of clicking simultaneously? Sounds like a battery power issue....battery, cables, grounds. What did you do to the battery? Really make sure that the battery is fully charged. Jumping a weak/dead battery also will not work.
Definitely sounds like your battery is shittin the bed. How old is the battery? How did you check it?
If the battery is good, then I would check all your connections, make sure they are clean and tight.
Quick test would be to try jump starting it. If it jump starts fine then you know your battery and\or alternator is kaput. If you end up replacing your alternator, make sure you get your battery charged elsewhere before putting it in with the new alternator. Sometimes the new alternator will burn out trying to charge a very low or dead battery.
vtechjunkie
16
Jan 16, 2016 01:18 PM
rockcity
Apr 16, 2008 07:06 PM
