Using a 1000 watt amp on an odyssey pc680??
Old Sep 12, 2009 | 06:10 PM
allentownrep's Avatar
Default Using a 1000 watt amp on an odyssey pc680??
Currently in my prelude i have an odyssey pc680 battery. Reason why i have that battery is because i track my car, but it is also my DD. I came across an awesome deal on an audio system that i couldn't pass up. Its a kicker 15 with a sony 1000 watt amp. Figured I would remove the system when it was track time.. What do you guys think? Can I put the system together with the battery and make it work? Should I install a cap for good measure? I searched and i really couldnt find anything that was relevant to my question..Thanks H-T ASV.
Miguel
Old Sep 12, 2009 | 09:10 PM
98civdx's Avatar
Master Detailer
Default Re: Using a 1000 watt amp on an odyssey pc680??
while the car is runing power isnt coming fromt the battery, so inless your going to be runing it alot when the car is off id say your fine, just make sure your alternator is up the task of runing it.
caps are really only a band aid fix, yes they work but, youd be better off throwing a high output alt in.
edit-- forgot to ask how many watts your runing rms?
Old Sep 12, 2009 | 10:40 PM
mrdeadman's Avatar
They let me pick
It's a sony so probably 250rms.
Old Sep 12, 2009 | 11:03 PM
well the amp that i have is a Sony Xplod Model # XM-1652Z.
The kicker is a Comp VR 15, 1000watts peak and 500watts rms.
Old Sep 12, 2009 | 11:04 PM
LOL, are sony amps really that bad?
Old Sep 12, 2009 | 11:59 PM
98civdx's Avatar
Master Detailer
they can be
i have a sony 1000 watt 2 chanle and its not that bad, my 2 12s beat the **** out of my car.
Old Sep 13, 2009 | 12:06 AM
Nice..thanks for your help 98civdx.
Old Sep 13, 2009 | 07:35 AM
fcm's Avatar
fcm
Old Fart
You will have no problem, other then the amp is underpowered for that sub, amp is 1x400W RMS into 4 ohms, not stable below 4 ohms when bridged into mono.
As mentioned, once car is running the alt. supplies power.
Upgrading the alt. is the only way to get more current, [power] but a cap will help "stabilize" current to the amp at peak demand. 94
Old Sep 13, 2009 | 08:41 AM
I looked up the amps that a prelude alternator puts out. Its about 95-100amps. I usually dont turn the bass up really high. I like to have some bass but only to where i can here it. Not where it completely drowns out the music. Would that have any effect?
Old Sep 13, 2009 | 03:41 PM
mrdeadman's Avatar
They let me pick
You are fine. Don't worry about it unless your headlights or other interior lights dim on a strong bass note.
Old Sep 15, 2009 | 07:23 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Your only problem is going to be if you are rocking the heck out of your system. The amp will drain the battery and power what it needs from the alternator. Now the alternator is going to have to charge the battery and run the amp. Worse case is that while rocking the system when the bass hits hard it will just shut off the car. The alternator has no more current to run the car and the system and charge the battery.
I had to fix of couple of cars like this on the west coast. One guy brought in a civic couple with a alpine pdx1000mono and a pdx4.100. This is alot more then you but if he played his music at high volume it would quickly kill the car battery and shut the car off on a bass note.
Also had a car that had a kicker 800watt amp and it did the same thing.
as long as you are easy on the volume **** you would be good to go. Text your alternator to make sure its up to par.
Old Sep 15, 2009 | 07:45 PM
mrdeadman's Avatar
They let me pick
Did the amp drain the battery because it was pulling more current than the alternator was capable of putting out? Because that would make sense.
Old Sep 15, 2009 | 08:12 PM
My alternator was replaced about 2mths ago. Replaced ALT and belt while i was at it. Like i stated above, i just like to have a little bit of bass. so the gain on the amp would be kept at a minimum, and ill control the bass from the subwoofer setting in my CD deck. Its just to have some bass in my car. Also im only going to be powering one kicker 15.
Old Sep 17, 2009 | 08:46 AM
Yes, You could not play the system at a good volume before the battery just went dead the amp would motorboat and the car would idel low when the bass hits. I reccommend not trying to run more then 400-700 whats rms off something like this. And 700 is pushing it.
Old Sep 17, 2009 | 11:22 AM
fcm's Avatar
fcm
Old Fart
His amp is 1x400W RMS inbto 4 ohms. 94
ezza
Mar 4, 2009 05:37 PM
doubledee
Audio / Security / Video
Jul 30, 2008 12:15 AM
SD1222
May 11, 2006 06:45 PM
tub_sephiroth
12
Mar 6, 2004 09:17 AM
Mike813
Oct 9, 2003 09:38 PM
