b18c into 99 si
yes u can. ur swap will be super easy..
the only thing u may have to do is extend a couple wires
and it also depends which ECU u will be using to run your car.
if its obd2a or obd1 u will need a jumper harness
i will prob use a 99 gsr ecu, will it fit? wat wires do i need to extend? do u have pixs or know anyone with pic?
You should set a timer and see how long it takes to swap. 10 bux says you can have the old one out and new one in and running in under 2 hours with proper tools/help. any takers? lol
2 hours was a joke, unless your super duper dedicated, with several other people.
so its a plug and play thing? no need for extra wiring? actual my car is a 1999 civic hatchback, but i have 99 b16a2 in it.... just wanted to swap out for gsr
99 gsr is obd2a, 00-01 gsr is obd2b. i have the obd2b 00 gsr swap in my 00 hatch. been running an 00 si ecu for about 80 miles now with no codes.
pretty sure im not giving it enough gas. just need it to pass smog.
and i got a obd2b-obd1 harness waiting for a gsr obd1 ecu.
ballplayer
17
May 11, 2005 03:45 AM
si1999
Jul 5, 2003 07:39 PM
chrisir19
Apr 29, 2003 11:20 AM
