head gasket question
Old Sep 12, 2009 | 04:28 PM
Rickdogg's Avatar
Default head gasket question
does the block have to be completely clean of the head gasket before i put the new one on? cause i got most of it off but its still a little black i just dont wana scratch it no more
Old Sep 12, 2009 | 04:58 PM
martn53's Avatar
Default Re: head gasket question
get some sand paper and oil and sand the rest off
Old Sep 12, 2009 | 05:04 PM
ef2 pimp's Avatar
http://www.youtube.com/watch?v=2lM7I...layer_embedded
Old Sep 12, 2009 | 05:05 PM
91_ef_hb's Avatar
better safe then sorry
Old Sep 12, 2009 | 05:12 PM
Rickdogg's Avatar
what kinda grit would be good to use? i would use the drill but im poor haha
Old Sep 12, 2009 | 06:31 PM
ninjasruleyou's Avatar
don't use sandpaper, you will take more off on some spots than others......the best way is just to use a scraper and hand scrap it off......it might take a lil work but its was safer than using sandpaper....the surface needs to be dry and cleaned of any oil residue.....if you do this, there shouldn't be any problems.
Old Sep 12, 2009 | 07:59 PM
sde780's Avatar
I used a razor blade and mine came out pretty clean. Don't sand it, they make gasket remover
Old Sep 12, 2009 | 09:00 PM
D16SiHatch's Avatar
gasket remover doesn't work for **** on old composite type gaskets. ask me how i know lol. an angle air grinder at a low speed with a high grit pad takes off this type of hg material with ease. you would have to really grind the almighty hell out of a particular area to actually affect the new hg sealing properly.
Old Sep 13, 2009 | 05:50 AM
yeah i agree that gasket remover doesn't work well with the old composite gaskets
Poleke
Jun 20, 2019 01:49 AM
YoungMoney_Twit
Jul 8, 2018 10:11 PM
cfwthb_94
Aug 17, 2009 07:48 PM
firstgenrex
Sep 24, 2003 08:37 AM
