1994 Front Axle Replacement
Old Sep 12, 2009 | 11:45 AM
94WhtTeg's Avatar
Default 1994 Front Axle Replacement
So Changed my oil today and noticed axle grease all over my drivers' side wheel, seems like it started this week, look at the boot there's a definite tear. Had my buddy look and he said passenger side boot isn't looking much better...
So I'm wondering what are the best replacement Front Axles? Should I go OEM or Aftermarket?
Also there is a circular thing in the middle of the shaft looks like it leaks something? right below oil pan, my buddy wasn't sure if it came on the front axle or if it was something else?
Any ideas?
It's a 94 LS coupe w/LSVtec
Thanks!
Old Sep 12, 2009 | 12:11 PM
1992Si's Avatar
Default Re: 1994 Front Axle Replacement
Go with aftermaket, but buy the better axles, don't waste your time on the free life time replacement ones. To many horror stories about them. I have changed as many as 4 before I got a good one.
That rubber thing on the axle is nothing.
There must be a sticky here somewhere on how to change them. A lot of us have.
Quick list.
Break torque on the axle nuts first before you jack up the car and pull the wheels.
to remove the lower ball joint, hit the LCA with a 5lb hammer, hard. leave the nut on the ball joint threads in case you miss with the hammer.
After you have hit the LCA a few times try and pry the spindle up with a big screwdriver. It will pop to release but the weight makes it look like it hasn't moved.
You may want to get tranny axle seals too. They are different sizes.
Oh drain the tranny oil or jack one side up really high at a time.
Use grease and anti-sieze compound on the threads when you re-assemble.
Find a buddy who has done this before. It will make things much easier.
Old Sep 12, 2009 | 12:38 PM
94WhtTeg's Avatar
So who makes/what are decent aftermarket axles? and a good place to get them?
I don't need 400+hp ones or anything
Old Sep 12, 2009 | 01:24 PM
gsrvong's Avatar
don't spend $1 zillion dollars on stuff you don't need. If your car is stock, oem or autozone axles are fine.
Old Sep 12, 2009 | 01:46 PM
stocker2shocker91's Avatar
I requested a short story for a title.
x2 on this you dont need to buy all that **** if u dont need it the only problem you have to really worry about with autozone ones is makin sure you acutally get the right ones haha be sure to compare.
but if you insist on aftermarket the only place i can think of is the driveshaftshop
Old Sep 12, 2009 | 02:13 PM
94WhtTeg's Avatar
Well it's not exactly stock making 183whp possibly more with recent bolt ons, but hardly a 300hp car hehe
Is there a particular brand? I don't mind spending the money if the product is worth it (except $700 for 400hp axles or something like that)
Thanks!
Old Sep 12, 2009 | 06:06 PM
gsrvong's Avatar
Thanks!
OEM is worth every penny. That's all you need seriously unless you absolutely don't want oem or autozone. But if you do indeed want aftermarket axles, the driveshaft shop has "oe replacement" for $359.
Old Sep 12, 2009 | 06:08 PM
Spawne32's Avatar
http://www.driveshaftshop.com/pdetail.php?pid=32
Old Sep 12, 2009 | 06:47 PM
srok1's Avatar
I just changed my axles a week ago or something like that. You should just bring your old ones in to autozone and get them redone, I think thats where they do it. But I bought the Autozone Duralast ones and now my **** vibrates under acceleration, I ****ing hate it.
Old Sep 13, 2009 | 01:03 PM
94WhtTeg's Avatar
I see, well it was recommended to me to just get OReillys' or Autozone ones, and my dad gets a discount there, but I don't want any issues obviously...
The first guy that replied said to avoid OEM...
Old Sep 13, 2009 | 01:15 PM
hOnda_hiEn's Avatar
just get the ones from autozone with the lifetime.. or buy some from me.. pm if interested..
Old Sep 13, 2009 | 02:34 PM
gsrvong's Avatar
Since when do you avoid OEM if you don't go aftermarket? Not trying to argue a point, but wouldn't you go OEM before Autzone or anything else?
Type 56
Suspension & Brakes
Apr 4, 2017 09:30 PM
Pwnmeister
Jun 25, 2013 07:55 AM
koulaid
Sep 7, 2006 06:00 AM
BigBoulda
Jan 25, 2006 08:13 AM
sleepinbeauTEG
Jan 21, 2005 08:37 AM
