97 Accord LX- No spark, changed coil/control module. Help!
Hey guys.
Got a 1997 Honda Accord LX (F22B2) that's just not sparking. Tried sticking a screwdriver up in the plug to see if I could arc off something, but I get nothing. Everything else seems to be fine. I replaced the ignition control module- nothing. I replaced the coil- nothing. The ONLY other thing I could think of is the crank sensor? If not that, probably something major like the ECU (which, I really can't see going..).
Has 160,000 miles on it. Taken good care of ('course, everyone says that!).
Can anyone give me any ideas? Thanks in advance!
betcha its the main relay. have you changed that? its located under the drivers side panel where your knees are. it has a 10mm bolt holding it in. that should solve your problem
work backwards, if no spark to spark plug, check cap, then rotor, then coil, then dist wiring. If you dist is not getting power check connections and chasis wiring. if no power still check ecu pins, still nothing check ignition.
