NEED HELP! JDM D15B Thermo Switch the same as USDM D15B7?
Hey guys,
I swapped a D15B into a Del Sol. I need to know if the JDM D15B has the same fitment as the USDM D15B7. I recently picked up a new thermo switch (radiator fan switch) from Advanced and it isn't even close to being able to fit. The 2 prong plugs are even different. I am using the harness from the D15B7 so did I just get the wrong part or what? Any help would be great trying to get this fixed today. thanks in advance!
The only difference in the standard harness for the D15B and the D15B7 is that one has 2 extra wires for the VTS and the VTM. Other than that they are 99.9% the same. When I just swapped mine I did indeed find a few things that didn't match up as well. For instance the O2 sensor that came with my D15B didn't plug up to my harness, had 2 wires instead of 4.
As for your specific issue, let me see if I can find what you are looking for. BRB.
Soooo.... probably wanna go with the part you'd use on a Z6
Sehc Tib Alli Zerif!!!!!
Sep 11, 2013 09:22 AM
jdmDAsix
Jul 24, 2007 05:59 PM
