D16Y7 Header Compatability?
Will an after market header for the d16 bolt up to the stock exhaust piping of a d16y7 motor? I understand that this will delete the CAT being that it is a part of the d16y7 manifold, and an 02 sensor must be lengthened, but is everything else a bolt-on procedure?
I just did this on my 99 DX.
The header that I used had 2 spots for the O2 sensors top & bottom. For the Bottom o2 sensor I did not have to extend my wires at all I just rerouted the wire from the o2 sensor around the back side of the engine and unclipped the connector from the bracket.
However if you need to have a cat due to emission requirements where you live you will have to use a EX exhaust and buy a cat. If not the header does bolt right up to a stock dx exhaust.
It does work fine as long as it has the 2 spots for the O2 Sensors instead of 1. Many headers have both spots just because some of the D16's have the O2 Sensor in front of motor like the D16Y7.
ManitobaCivicDX
25
Jun 18, 2012 11:06 PM
Nicaraguense13
Nov 3, 2010 03:00 PM
CeoStatus0
Jul 25, 2003 04:58 AM
