NEWB NEEDS HELP IN CHI TOWN PLEASE! d16z6 swap
Hey guys. I have a 1990 civic Hatch BASE MODEL.
D15b1
4 speed
You know the deal
BUT I DONT! i Bought a d16z6 swap including the p28 wire obd harness and 5 spd trans. It also has the axels and everything needed i guess.
I also have an extra d16z6 head to build up.
But i hear that the base model has smaller suspension components up front. Could you guys please help me put together a list of everything i need to get this going ?! Its for my Daily driver.
Another thing is if anyone knows where to get this done in the chicago land area. OR! if there are any guys with some serious honda knowledge willing to help out! If someone swaps this for me ill give you my old motor and trans which runs great and ill give you the extra head i have. Plus cash if i have to. BUT I NEED THIS DONE. Please help out guys. THanks alot! I appreciate it.
IF you have good info email me at nsport69@aol.com thanks
D15b1
4 speed
You know the deal
For one don't post your number directly on these sites, it’s not smart. Also do yourself a favor and stay away from One6, The Whip Factory, and practically all the "performance shops" in the Chicago-land area. They will rip you off and steal from your car. It is proven time and time again, they are con-artists.
How much cash are you talking, LOL???
I just need it done. If your serious about helping me we can talk.
I was wondering about the shops. But now i feel screwed who do i go to?
hey nate heres a list of everything you will need for the z6 to run properly
motor
tranny
axles
clutch kit
flywheel
correct intake manifold/throttle body with map and tps sensors
Z6 DISTRIBUTOR
you can use your obd0 alternator
any d series headers
convert to 4 wire 02
run your injectors with or without a resistor box
good set of mounts
convert to multiport(theres TONS AND TONS of these write ups)
obd0 to obd1 jumper harness
swap the 2 outer wires on the tps
run the wires at b10 and b12 for the dizzy
p28 ecu
if your running hydro tranny use the hydro conversion kit
crx si throttle cable
oil n filter
anti freeze
trany fluid
brake fluid
GAS LOL
thermostat
hoses to fit onto the radiator
you can use your old obd0 a/c bracket and compressor on the z6(if it dont come with 1)
wires FOR the z6 and plugs(old ones wont work)
new cap n rotor
intake/exhaust mani gaskets
throttle body gasket
like 2 rolls of tape and 5 or 10 feet of black wire loom lol
soldering gun/solder
heat shrink tubing and crimpers/strippers(the tool not the girls)
injectors from any vtec sohc
timing belt
set the timing
might as well replace the oil pan gasket as well
if it needs it, head gasket
rear main seal if its leaking(you gotta split the tranny any ways)
and some other small misc ****
motor
tranny
axles
clutch kit
flywheel
Z6 DISTRIBUTOR
good set of mounts
p28 ecu
oil n filter
anti freeze
trany fluid
brake fluid
GAS LOL
thermostat
new cap n rotor
timing belt
set the timing
www.rcautoworks.com tell them lewy sent you. they are located in bridgeview about 30 min outside of chicago they can take care of anything you need with very good prices.
blackcom
Oct 17, 2005 07:28 AM
