Blowing fuse at high rpms getting on it
1990 civic dx 94' LS engine with B16 cable trans OBD-1 converted. The fuse for the ecu, fuel pump, main relay, etc. blows when heavy accelerating after upshifting. I started having this problem after I switched transmissions. I had a GSR hyrdo trans in it before. After the switch it blew the fuse when I was cruising to work. I got it to blow everytime I upshifted and heavy accelerated. now I replaced the ecu with a 95' chipped LS ecu from a 94' LS ecu stock. So far it blew the fuse once at a high rpm. Dont know where I was because I dont have a tacometer but will install one soon. Have anyone had a problem like this?? Is the ecu seeing something weird with the engine accelerating so fast with the short geared trans??
