H23 in CB7 FAIL help
swapped in a H23A1 into my CB7 with a h22 trans..problem is that wen driving if i push the gas pedal half way or full the car starts to sputter n not move. it doesnt die. i have a OBD1 gsr computer chipped for a h22..and the car also surges.what could be the problem? ive been told it could be: computer,iac,tps
lmk thanks
lmk thanks
Well if it's chipped for an H22 and VTEC is not disabled, then it's probably looking for VTEC and not finding it. A VTEC diagnostic trouble code could be why it's falling on it's face when you try to give it gas. I would have the ecu chipped & tuned for a non VTEC H23. That could probably solve both of your issues.
If you have it tuned and it doesn't solve the surging issue. You should take a look at your vacuum lines and check for leaks. As well as clean the IACV and check the wire connection.
If your P72 is chipped and tunable then you should be able to use it. After you find a friend/tuner to disable VTEC and re-tune it for an H23. Or if tuning is not an option you could find a stock OBD1 H23A1 P14 ECU.
Ebay Item number: 140344496510 = 37820-P14-A11 M/T ECU $139.00 or best offer.
I ran my F22B2 SOHC non VTEC with a chipped and tuned OBD1 P72 for a year. It all depends on the tune(r).
ohh okay yeah..i dont think tuning is a good option for me ryte now..lol cuz wen we did the motor swap we js taped up the vtec plug in and its like a wire straight to the ecu..so basically being that my ecu is for vtec thats was causing my h23 to not run properly?
