high compression build questions
Old Sep 11, 2009 | 10:17 AM
GYChris's Avatar
Default high compression build questions
i had a few questions about a build i am doing, i was wondering if it would be fine to run on pump gas.. i did the online calculator and it came to 13:1.. heres the setup
b16 head - all stock
b18c1 block
LS crank
LS rods
CTR pistons
OEM head gasket
arp head studs
would this setup be ok to run on 93 octane? anything i could do different to have a decent setup? is this setup just retarded?
Old Sep 11, 2009 | 10:45 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: high compression build questions
It is not pump gas friendly nor a really good combination for whp production.
Go with either RS machine ITR or P30 pistons.
Old Sep 11, 2009 | 11:54 AM
lohatch's Avatar
if you want to make 160whp go for it.
get rid of those bigass domed ctr pistons.
Old Sep 11, 2009 | 12:27 PM
Scott_Tucker's Avatar
The cam is going to dictate what compression ratio you can run not the fuel . . .
Old Sep 11, 2009 | 06:55 PM
GYChris's Avatar
alright thanks for the replies fellas. looks like i will be going with some p30 pistons, since i can get some for 20 bucks right now lol
Old Sep 11, 2009 | 08:11 PM
DDTECH's Avatar
lol CTR pistons.. when will people learn.. that piston is a PCT, **** Crap Trash.
Old Sep 12, 2009 | 10:05 AM
Eli2's Avatar
Whats wrong with the ctr's?
Old Sep 12, 2009 | 10:07 AM
DDTECH's Avatar
alot..
For starters they came in a b16 block, if they are used, they shoudl only be used, in a b16 block
They're very heavy..
They distort the flame combustion process
They have too much of an angle on the dome
They are just **** pistons..
Putting these pistons in anything but a b16 block.. will have your CR through the root.
deck height, rod length, crank , all these play a role in CR and these pistons.. put you at high 13's in a gsr or ls block.. no matter what combo you use.
cisurfer1
Feb 20, 2006 08:31 PM
riceball777
May 6, 2003 06:04 PM
ALMOSTAFERIO
Apr 10, 2003 06:05 PM
wm5holla
Mar 3, 2003 09:26 PM
-Racer X-
25
Apr 9, 2002 06:42 PM
