Breaking symptoms..
Old Sep 11, 2009 | 09:50 AM
norcalB18's Avatar
Default Breaking symptoms..
This might be a little long. All help would be greatly appreciated
When i drive around my breaks seems to work fine untill after 15 mins of using them... the ABS light comes on and my breaks would hold pressure for 2 seconds and starts to sink to the floor everytime i try to use them. When i would step on the breaks the idle would jump up and down sometimes when the abs light is on..
The ABS code is 8-1 abs function. I'm not even sure on how to fix that. Checked the master and saw no leaks and not sure of what to do from here on..
Old Sep 11, 2009 | 09:52 AM
mrdeadman's Avatar
They let me pick
Default Re: Breaking symptoms..
Your abs is probably shittin the bed. Is there fluid in the abs system? When was the last time you bled the brakes?
Old Sep 12, 2009 | 05:27 AM
ghost_xero's Avatar
bleed them, and also check the brake booster, if air is escaping then it will make everything else lose pressure as well
Old Sep 12, 2009 | 07:06 AM
suspendedHatch's Avatar
The fluid could be old and full of moisture. When it gets hot the water boils and then the pedal sinks to the floor.
Breaks = when something breaks.
Brakes = brakes on your car.
Fliplm0de
Nov 15, 2008 10:57 AM
b18LS
Oct 25, 2008 09:55 AM
herrgolf
Jul 22, 2008 12:11 PM
SpeedFreek34
Jul 22, 2007 05:43 PM
jonzel
Aug 18, 2005 04:47 PM
