upgrading to spoon front brakes and integra rear disk!!!help....
ok i got a 1993 honda civic hatchback cx with stock brakes right now. looking to upgrade to spoon front calipers /w 4x114 prelude rotors redrilled to 4x100 and also upgrading to 1996 integra rear disk brakes. with this upgrade will i also need to upgrade to like integra brake master cylinder and proportional valves also or can i just still use my stock ones??? the reason i say this is cuz if it is not neccasary then it would be good for me to save some $$$ plus my brake master cylinder is also new.
Yes, you had drums in the rear. Now that you have discs, you need the correct prop valve for rear discs. The brake master cylinder really doesnt matter, but an ITR 1" would be best!!
i did rear disk conversion...is integra brake master cylinder 7/8 good enough?..and wat emergency ca
fastest
Jun 9, 2004 08:54 PM
