Caliper question ???
Old Nov 14, 2001 | 09:27 PM
Group 03's Avatar
New User
Default Caliper question ???
Is there anybody here upgrade their rear caliper.
Old Nov 14, 2001 | 09:28 PM
Type Goch's Avatar
New User
Default Re: Caliper question ??? (Onion Kid)
do companies even make rear calipers? pardon the ignorance.
Old Nov 15, 2001 | 01:57 AM
AJ PwR's Avatar
I don't think any companies make rear calipers for the ITR . I think rear calipers upgrade are not necessary cuz front brakes upgrade are enough for most civic & integras.
If there is a rear caliper upgrade kit you might need to upgrade your master cylinder and booster as well since the stock master cylinder and booster may not have enough power to run bigger pistons calipers at the rear brakes. I think this upgrade will be way too expensive and not too effective.
Old Nov 15, 2001 | 05:39 AM
Flux's Avatar
Default Re: Caliper question ??? (AJ PwR)
I'm still a little confused about brake upgrades - help me out. It is my understanding that the brake bias and balance of the car is very important (duh) and something you shouldn't just go messing with casually. I read a GRM article several months ago about this topic, and the basic conclusion was that you can't just go slapping on brake upgrades randomly or in random places (front only) and expect your car to behave properly.
I would think that the brake system of the Type R has been engineered in such a way that it is properly biased. When throwing on bigger rotors, 4-pot calipers, etc. on the front of the car while leaving the rear stock I would think this would have some not so desireable effects..
Can anybody comment on this that knows more than I do....
Old Nov 15, 2001 | 05:42 AM
sackdz's Avatar
Default Re: Caliper question ??? (Flux)
There are valves aka brake bias controllers that will enable you to fine tune your balance for your trail braking pleasure.
Old Nov 15, 2001 | 06:54 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
For the ITR, the rear suspension setup is different so that the tail would step out easier, ie. narrower track, relatively stiffer suspension elements, etc. So even by just putting in aggressive track pads in the rear stock calipers would cause unintentionl lock up sometimes. That's why the upgrade for the rear calipers is not necessary even when the fronts were upgraded. Just for reference, all (or most?) race ITRs out there in the US and Japan are keeping the rear calipers stock. That should explain something.
raverx3m
Suspension & Brakes
16
Jan 2, 2013 08:51 PM
mynameizstitch
Sep 11, 2009 09:19 AM
gsrturboda
Suspension & Brakes
Jan 9, 2009 08:49 PM
EKSedAndy
Apr 30, 2008 04:37 PM
Zboud
Honda Motorcycles
12
Jan 13, 2005 06:20 AM
