90 Civic Sedan Upper Control Arm/Balljoint Replacement???
Old Sep 11, 2009 | 04:03 AM
dbailey's Avatar
Default 90 Civic Sedan Upper Control Arm/Balljoint Replacement???
Guys my upper balljoints are shot bigtime and I need to replace them. Any directions on hot-to? Doesn't look like it would be a big deal to do it but sometimes those are the ones that bite you. I understand you have to replace the entire control arm to replace balljoints on the uppers. True? Thanks guys for any suggestions.
Old Sep 11, 2009 | 04:18 AM
mntuner2's Avatar
Default Re: 90 Civic Sedan Upper Control Arm/Balljoint Replacement???
You need to remove the shocks because there is a brace between the two anchors/bushings. Other than that, yeah its a piece of cake. Remember to use new cotter pins.
Old Sep 11, 2009 | 04:20 AM
~sp33~'s Avatar
EFB055
I didn't remove my shock when i replaced mine...
Old Sep 11, 2009 | 04:51 AM
johnnyonth3spot's Avatar
on 90-91 you dont have to replace the whole controle arm. Just remove the snap ring find a large socket and place the control arm between 2 pieces of wood the club it a few times to remove the old ball joint, if you have access to a press even better but most peaple dont have one handy. New upper ball joints are hard to find autozone has duralast, ebay has some.
Old Sep 11, 2009 | 05:21 AM
dbailey's Avatar
Oh yeah I remember that brace that goes across there where it mounts to the body right? No way to get it out of there without removing the strut?
driveslow
Mar 6, 2009 04:53 AM
Akalima
Suspension & Brakes
May 12, 2007 10:23 PM
RAYThOM
May 24, 2005 04:10 PM
^Sammy]!.
Sep 22, 2003 05:47 PM
sitrucjr
11
Oct 13, 2002 01:02 PM
