Smog problems and smog is due next month!!
Old Sep 10, 2009 | 08:33 PM
royalrebel's Avatar
Default Smog problems and smog is due next month!!
So heres the deal i have a 00 ek with a 97 gsr swap. It does not have a cat, has dc headers, and aem intake. I dont want to get it passed illegally. I want to BAR it and of course smog cuz its due next month, so i need a cat obviously.
So my question is do i just get a cat and have it welded on?
What kind of cat do i need?
thanks
Old Sep 10, 2009 | 08:37 PM
mortificationrock's Avatar
Default Re: Smog problems and smog is due next month!!
Well if my memory dont serve me wrong, i believe to bar the engine it has to be the same year as your chasis or newer. So there is your first problem. I could be wrong or you could be lucky and they wont check the stamp on head. I also believe you need a cat for a integra.
Old Sep 10, 2009 | 09:22 PM
royalrebel's Avatar
so do i just buy an integra cat and have it welded it on ??
Old Sep 10, 2009 | 09:25 PM
soclean1k_JDM's Avatar
you need 00' swap to get it bar'd and the rules have changed alot its getting harder to bar swaps no way to fly straight with what you have.
Old Sep 10, 2009 | 09:38 PM
boxeocampeon's Avatar
i wouldnt weld it you should get a bolt on one and cut the other piece and swap it back once youve smogged it. thats what i would do
Old Sep 10, 2009 | 09:40 PM
wannaBjdmca6's Avatar
u need a same or newer obdII engine bruh. i seen u live in cali so yeaaaaa BAR is a no no for u
Old Sep 10, 2009 | 09:41 PM
royalrebel's Avatar
ok so getting it bard is outta the picture, but i still need to pass smog...
would i buy a gsr cat and bolt it on?
obd1 or obd2?
and would it pass cuz their going according to civic preferences when i have a gsr.
Old Sep 10, 2009 | 09:45 PM
Well since you cant bar it, and replacing cat would be more $. I would just get someone to pass it.
Old Sep 10, 2009 | 09:54 PM
royalrebel's Avatar
well that can get a bit pricey. it would be cheaper to buy a used cat bolt it on and smog.
but i dont know what obd cat to get since its a gsr in a civic
Old Sep 10, 2009 | 10:23 PM
tico's Avatar
well first off u cant buy a used cat it is illegal in Cali to sell used cats. you cannot bar ur civic because of veh/engine year. what i would do is go to a shop that sells cali certified replacement cats and have them put one on, smog it and see if it passes... the smog tech will tell u to go home untill u have a legit cat... start there. make sure you have your evap system still in and operational in your vehicle, no CELS, if you do dont try and pull a bulb or fuse, he has to hook a scanner to it.. this will get you to wear u need to be
Empyre JDM
Dec 6, 2010 07:32 AM
nek9
May 25, 2006 09:02 PM
DirtyD12Dozen
14
Feb 22, 2005 09:18 AM
b00sted4dr
Feb 28, 2003 03:53 PM
HBCthugg
May 3, 2002 11:50 PM
