OBDI B18C1 Swap into 99' civic dx help!!
Old Sep 10, 2009 | 07:30 PM
Dx-R Ryder's Avatar
Default OBDI B18C1 Swap into 99' civic dx help!!
Ok heres the thing, I got one of the greatest deals on a GSR engine swap which includes axels, shift linkages, ecu, and other goodies. But theres one thing I'm not too sure about. So far my engine is going to be machined work. I know that I will need to buy a new clutch kit, gasket kit, and a new timing belt. The main question is, since I'm going to use the P72 ecu from the gsr, do I still need to buy a whole new wiring harness by having an Obd1 wire jumper to odb2?? or I don't need it at all since I'm just using the original ecu that comes with it. And this engine is going to be transplanted into an Obd2 chassis. Thanks in advance!
Old Sep 11, 2009 | 10:03 AM
98civdx's Avatar
Master Detailer
Default Re: OBDI B18C1 Swap into 99' civic dx help!!
dont buy a new harness. yu can use yours you may just need to switch a few plugs for the dizzy. sorry im not sure what else.
you will need a jumper harness to use your ecu.
Old Sep 12, 2009 | 04:47 AM
ihatesilver's Avatar
you don't need another entire wiring harness. yours is a one-piece anyway. it would be a huge bitch to swap it out.
KZK civic
Jan 10, 2012 01:46 PM
MurtazaDSM
Nov 3, 2009 03:48 PM
93gsrhatchbrid
Dec 6, 2005 05:20 PM
cramers coupe
May 29, 2005 05:50 PM
spektrum
Nov 23, 2002 04:15 PM
