help valve compression
Old Sep 10, 2009 | 04:17 PM
melissashelton1's Avatar
Default help valve compression
I did a head swap y8 to z6. When I first started car there was a lite ticking noise. I had a buddy who said a valve needed to be adjusted. So he decided to adjust all the valves. When I went to start car this time there was a bunch of noise much much worse then the original problem. He tried again no change now my compression is low in all but the forth cylinder where the noise originated from. Is this because the valves are all wrong. If so I will have them done right by someone else. Or is it more of a problem????? PLEASE HELP
let me give you a little history on the z6 head. I bought from a guy that had it machined shopped then he drove about 300 miles on it when his block went out thats how I ended up with it. It sat for 2 months before I put it on my car because my y8 head blew. Is this enough time to do damage to the head? Or once again did some dumb *** just screw my car by doing the value multiple time and now it worse. Just trying to give all info. Oh and I didn't do a compression test before he start messing with valves so I have nothing to compare to.
Old Sep 10, 2009 | 04:45 PM
boxeocampeon's Avatar
Default Re: help valve compression
usually when one cylinder is that off it could be a bent valve which is way more of a problem. also he might have done the valve adjustment wrong. i think your having misfire. is there a check engine light?
Old Sep 10, 2009 | 05:17 PM
Old Sep 10, 2009 | 09:35 PM
Im thinking its a bent valve. What happens when you drive it? Do you have engine hesitation?
Old Sep 11, 2009 | 04:21 AM
the first time i took car on test drive ( with just the lite ticking) it ran nice. But after he attempted to due valve adjusting it ran horrible so much was going on loud noise didnt want to go ect.. So he did vaule again after each attempted it just got worse
Old Sep 11, 2009 | 06:09 AM
usually a knocking noise from the engine means a bent valver or blown head. if its more like a ticking sound it could be misfire. Do you have any check engine lights on?
Old Sep 11, 2009 | 08:41 AM
The original sound was definitely a tick but now there is so much noise I cant tell. Yes the check engine light is on but it was on before I did swap. When I ran a code on it nothing ( before swap) so i assumed because there has been some modification. I think when the values where done he didnt have each cylinder in tdc because he said they dont have to be but im finding conflict with that??????
Old Sep 11, 2009 | 08:45 AM
nub's Avatar
nub
If this person tried to do a valve adjustment after you drove the car your valve lash is going to be wrong. Lash adjustment should only be done on a "dead cold" engine, as in sit overnight cold. Remember, metal is going to expand as it heats up. Your lash is probably double what it should be and will make a hell of lot of noise.
Old Sep 11, 2009 | 08:48 AM
hondamark35's Avatar
^^true^^
there's your problem!
don't let this guy touch your car anymore... you cannot adjust the valves with out putting each at TDC while your adjusting them! did he even use feeler gages? or did he just guess...?
i'd have the guy buy you a replacement head, that was just dumb on his part.
Old Sep 11, 2009 | 08:54 AM
When he adjusted first time on cold engine but is sounded horrible then he did it again with engine warm and again till i said enough I dont think this is working it sounds worse each time.
Old Sep 11, 2009 | 09:00 AM
Originally Posted by hondamark35
^^true^^
I bought the feeler gauge for him so yes but if not who knows what he would have done. I dont do engine work which is why i had him do it but obviously I know more than him. I sure as hell can read and it says " TDC" each cylinder. After doing much research I think I can do the value adjustment myself but my worry is now there is more problems than just a simple tick that i start with. What also concerns me is he did the swap did he do that right????
Old Sep 11, 2009 | 10:11 AM
nub's Avatar
nub
As stated before, don't let this person touch your car again. Since this person installed the head I would double check the mechanical timing and redo the valve lash. You didn't say exactly what kind of work was done to this head before you got it. Something to keep in mind if the cam is no longer OEM, many aftermarket cam tend to be a little on the noisy side. Another source of noise may be a stuck LMA.
Old Sep 11, 2009 | 10:37 AM
Take it to a proffesional dont let that guy mess with the car anymore
CO_CReX
32
Jun 17, 2006 07:43 AM
nikolass
Apr 18, 2006 06:57 PM
grncivic91
Jun 18, 2002 12:50 PM
