Crx quarter glass moldings ?
Old Sep 10, 2009 | 02:53 PM
Rob.'s Avatar
Icon2 Crx quarter glass moldings ?
Anyone have a writeup on how to install these 1/4 glass moldings ??
I just bought a new set.
Old Sep 10, 2009 | 04:30 PM
Crx Jimmy's Avatar
Default Re: Crx quarter glass moldings ?
Its not easy. the window has to be removed. cut/rip the old ones off. then you need to cut away the glue behind the window using a myriad of implements to reach all the angles. (also rear interior pieces have to be removed to reach, at least I needed to) once the window is out cut remaining glue off. put new gasket on window put glue on car and install.
Old Sep 10, 2009 | 04:56 PM
Rob.'s Avatar
you cant get into this clip without taking the windows out ? :?
Old Sep 11, 2009 | 11:56 AM
SoCarCRX's Avatar
I was looking on doing this to my project. I figured this would be the best time since the car isn't running as of yet. Question: where would I find a complete molding kit for the CRX at?
Old Oct 12, 2009 | 09:16 PM
hatchboy's Avatar
Thats a great question, i would love to know the answer as well.
Old Oct 13, 2009 | 09:17 AM
sohcrx91331's Avatar
try this site out,i by alot of my oem parts for my crx here, hondapartscheap.com
Old Oct 13, 2009 | 01:56 PM
PuroMotor's Avatar
You can get it at your local honda dealer. They aren't that expensive. I paid around 45 bucks for both sides. But I paid around 80 bucks to have them installed since the glass had to be taken out.
also majestic honda .com has themn for 28 I believe.
Old Oct 15, 2009 | 04:52 PM
DAP91Si's Avatar
I ended up cutting out the clip and sealing the hole where the clip goes with silicone. I then carefully slid/pulled the modling on toward the front of the car. You have to be carefull and not damage the lip on the molding or will not be able to sit flush against the glass.
I did mine along time ago so I don't remember all the details. I think you can push it in on but I think that runs a risk of damaging the lip on the trim. If you pull it don't pull the ends or they may break off.
NOFX
Nov 11, 2013 08:46 PM
4twenty_CRX
Sep 28, 2007 04:38 PM
Full Race A6
31
Jul 10, 2004 08:43 PM
pony express
Jan 22, 2003 10:06 AM
