HELP!! New swap and radiator fan is not turning on and temp gauge does not work.
Old Sep 10, 2009 | 12:47 PM
b18cEK's Avatar
Default HELP!! New swap and radiator fan is not turning on and temp gauge does not work.
As topic states I just swapped an engine and the fan is not turning on and the temp gauge is not working either. I checked the plug and ground on the thermostat and both looked fine. Also made sure that the plug for the radiator was indeed connected, it was.
Old Sep 10, 2009 | 03:06 PM
b18cEK's Avatar
Default Re: HELP!! New swap and radiator fan is not turning on and temp gauge does not work.
ttt
Old Sep 10, 2009 | 03:27 PM
shawn_crx's Avatar
make sure you connectors are plug... temp guage is under the dizzy.. and fan switch should be on the thermo housing
Old Sep 10, 2009 | 03:41 PM
b18cEK's Avatar
i checked all and even switched out the 2 sensors with a motor I had laying around. no difference.
Old Sep 10, 2009 | 04:15 PM
shawn_crx's Avatar
Then start from the beginning.. bypass the thermo switch ( fan should kick on)
Ground the guage wire ( it should read hot )
Old Sep 10, 2009 | 04:19 PM
b18cEK's Avatar
how do i bypass the thermo switch?
Old Sep 10, 2009 | 04:31 PM
shawn_crx's Avatar
disconnect the connector (thermo switch)
stick paper clip between (Jump) the connector ( not the switch )
Old Sep 10, 2009 | 06:25 PM
b18cEK's Avatar
could the thermostat stuck cause the gauge not to work and the fan to not turn on?
Old Sep 10, 2009 | 07:29 PM
shawn_crx's Avatar
a stuck thermostat does not cause those two problems
Old Sep 11, 2009 | 03:46 PM
b18cEK's Avatar
fan works when i bypass the thermo switch. how do i ground the guage wire
Old Sep 11, 2009 | 06:19 PM
b18cEK's Avatar
i've checked everything. all wires, ground, fuses, relays. WTF is wrong!
Old Sep 11, 2009 | 06:25 PM
shawn_crx's Avatar
So your fan works when bypassing the switch..... Now check the gauge sensor.... I think they may be tie together.
1. Unplug the temperature gauge wire at the sending unit, most likely located under your dizzy.
2. Turn the ignition key to the on position but don’t start the engine.
3. Ground the temperature gauge wire to the engine using a jumper wire and watch the temperature gauge needle. If the gauge now reads Hot, replace the temperature sending unit.
Old Sep 11, 2009 | 07:05 PM
b18cEK's Avatar
the guage needle did nothing. I also swapped out my cluster for another cluster. Just to make sure that it's not my cluster.
I have even swapped in a temp sending unit from a different engine I had laying around and still nothing... arg!
Old Sep 11, 2009 | 07:25 PM
shawn_crx's Avatar
Try this
Connect a jumper wire to the sending unit terminal at the gauge to a good ground. Turn the ignition key to the on position. If the gauge now reads Hot, there is an open at the wire going to the sending unit. Repair and test again
Old Sep 11, 2009 | 07:29 PM
shawn_crx's Avatar
anyways trouble shoot your gauge first and see if the fan kick on, if it doesn't then your'll need a new thermo sensor also.
Old Sep 12, 2009 | 04:05 AM
b18cEK's Avatar
thanks
any other ideas?
Old Sep 12, 2009 | 09:52 AM
b18cEK's Avatar
no one else has had this problem?
Old Sep 12, 2009 | 10:29 AM
Former User's Avatar
Let the engine cool, top off the coolant in both the radiator and reservoir, and then bleed the cooling system of trapped air.
Old Sep 12, 2009 | 10:30 AM
b18cEK's Avatar
by bleeding it, you mean taking off the radiator cap and turning the engine on? If so, I have tried this.
Old Sep 12, 2009 | 10:31 AM
The bleed procedure may take 20-30 minutes:
(Do you have a bleed bolt?)
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below
Old Sep 12, 2009 | 06:37 PM
b18cEK's Avatar
not sure if I have a bleed bolt. its a obd2b d16y8 stock
Old Sep 12, 2009 | 06:40 PM
The Y8 doesn't have a bleed bolt, which matches the bleed procedure I posted.
Old Sep 13, 2009 | 07:24 AM
b18cEK's Avatar
tried it and fan never turned on. the top radiator hose gets hot and buttom does not...
Old Sep 13, 2009 | 07:35 AM
Replace the thermostat and repeat bleed procedure above.
Is there a chance that your radiator is clogged? If so, flush the radiator after you replace thermostat, refill with coolant, and then bleed.
Old Sep 13, 2009 | 08:15 AM
b18cEK's Avatar
i appreciate all the advice.
How do I tell if it's clogged?
