he said it would runs 13's easy.
Old Sep 10, 2009 | 12:42 PM
88CRXJ's Avatar
Default he said it would runs 13's easy.
i got an 88 CRX... but its got a b18c1 in it, with a b16 head, skunk2 intake mani, headers, hi-flow cat no muffler, b16 lsd trans, and a few other gizmos and gadgets. dude that had it last said it would run 13's. i dont believe it. you think its possible? it has been dyno tuned.
Old Sep 10, 2009 | 01:35 PM
20-EM2-05's Avatar
Default Re: he said it would runs 13's easy.
Yes it is possible. What you have is what some people call "Poor Mans Type R". Hell, I've seen B18C1 CRX W/ Bolt on's running low 14's.
Old Sep 10, 2009 | 01:43 PM
DC2uNer's Avatar
with you asking this question and driving!? probably not. j/k go to the track and find out playa!
Old Sep 10, 2009 | 01:55 PM
ek-g6's Avatar
Take it to the Track!
Old Sep 10, 2009 | 02:09 PM
88CRXJ's Avatar
yeah thats what he called it. trans is a real JDM too. w/ 7lb flywheel and stage 3 clutch. non-hydraulic. idk is all b16 trans's are cable?
haha. good one.
and i will! as soon as i put a new crank in it! which will be finished up sometime between this weekend and next. as soon as the bearings come.
Old Sep 10, 2009 | 02:20 PM
DC2uNer's Avatar
no some b16 tranny are hydro aslo.
Old Sep 10, 2009 | 05:12 PM
20-EM2-05's Avatar
Post pics/vid of how you ran on the track. We all would like to see haha. Oh and btw. What ECU are you running on ?
Old Sep 10, 2009 | 08:02 PM
88CRXJ's Avatar
if you read everything, i havent ran the track yet. gotta do a crank first buddy =P. it was originally an ls ecu converted for vtec then the setup was dynotuned.
Old Sep 10, 2009 | 09:22 PM
djviet2000's Avatar
what kind of numbers did it put down? post a dyno sheet
Old Sep 10, 2009 | 09:35 PM
keepinitrehaal's Avatar
x2
Old Sep 10, 2009 | 10:15 PM
SkidmarkEH2's Avatar
Originally Posted by keepinitrehaal
x2
3x
Old Sep 11, 2009 | 08:50 AM
88CRXJ's Avatar
i dont actually have a dynosheet. the PO is the one who had it tuned. ill see if i can get it from him.
Old Sep 11, 2009 | 10:00 AM
onebadd4dr's Avatar
u should run that...i had a gsr with CTR pistons CTR cams Skunk2 pro series intake mani, and bolts, with a gsr lsd tranny,on in my old 4dr integra db7 was running hondata s300...car ran a best time of 13.4 averaged about a 13.5-13.8....the car made 198whp, 156lbs torque
Old Sep 11, 2009 | 10:22 AM
88CRXJ's Avatar
haha thats sick. well this guy claims its gots 164whp. but i will see when he sends me a pic of the dyno sheet. if he can find it ill post it up when get it. it aint turbod tho but thatd be cool.
Old Sep 11, 2009 | 10:55 AM
ahcapone's Avatar
The HP sounds right but I'm not sure about the 13 but I'm no expert. What internal work has been done? Run it!
Old Sep 11, 2009 | 07:42 PM
88CRXJ's Avatar
no real internal engine work
Old Sep 12, 2009 | 08:08 AM
hmoobhero's Avatar
definetly need slicks to hit 13's with this setup.
Old Sep 12, 2009 | 08:15 AM
88CRXJ's Avatar
think so? oh and "internal" work.... f1 clutch, findanza 7lb flywheel. haha. thats it.
Old Sep 12, 2009 | 08:17 AM
teamcalloway08's Avatar
In a Crx? If I did not run 13's with that setup in a Crx I would be worried..On Dr's that is.
Old Sep 12, 2009 | 10:38 AM
88CRXJ's Avatar
sounds like, once i get my car back together. it will run low 14's, high 13's. which is good. cuz this d-bag down the road has a trans am. STOCK. runs about the same time and he brags cuz he thinks he's tough and has 8 cylinders. talks about how hes never been beat in his STOCK trans am. so ill go smoke him and make him cry.
Old Sep 13, 2009 | 03:10 PM
89simajewski's Avatar
Nothin better then puttin down d-bags who don't fully grasp the effects of weight to power ratio. I had a ef si with apexi ws exhaust,aem sri,and stage 1 clutch that surprized many d-bags in old v8. Enjoy the look in face when you blow by him.
Old Sep 13, 2009 | 03:30 PM
Sorry about the sloppy post i had my boy pulling me away from the computer.
Old Sep 13, 2009 | 03:37 PM
em1_civicsi's Avatar
13.4? any pics vid or anything
no bottle?
Old Sep 13, 2009 | 04:32 PM
88CRXJ's Avatar
haha nice thats what im sayin.
Old Sep 13, 2009 | 05:40 PM
Shawn C's Avatar
In The Garage
sounds like you've got a nice start there. interesting no one has mentioned the fact that a usdm GSR block (with oem flat-top pistons) with a B16A head on it (with its large combustion chambers designed to accomodate high-dome pistons) will yeild a low (without calculating it i'd estimate ~9.6:1) compression ratio. and if it's still rocking the tiny b16 cams, then it's not going to make much powa.
but.... throw in some jdm B16 or CTR pistons, a nice valvetrain and some ctr or so cams, and she'll scream
